Einleitung
The solid state drive stores some of the computer's files and has limited space. Replacement of the solid state drive is necessary if it is broken or there is no space left.
Make sure you are grounded before starting. To ground yourself, simply touch a metal object that is in contact with the floor for a few seconds.
Was du brauchst
Remove all 15 marked screws on the underside of the laptop using a #0 screwdriver.
x1 9.8mm Screw
x8 5.6mm Screws
x6 5.0mm Screws
Carefully pull the solid state drive in the direction shown to disconnect it from the port.
Eine weitere Person hat diese Anleitung absolviert.
