Einleitung
Sounds from the laptop will be coming from the speakers. If no sounds are coming out of the laptop, then the speakers may need to be replaced.
Make sure you are grounded before starting. To ground yourself, simply touch a metal object that is in contact with the floor for a few seconds.
Was du brauchst
Remove all 15 marked screws on the underside of the laptop using a Phillips #0 screwdriver.
x1 9.8mm Screw
x8 5.6mm Screws
x6 5.0mm Screws
