Einleitung
The wireless card allows the computer to connect to the internet or another device through Wi-Fi. Some wireless cards may also have a Bluetooth adapter.
Make sure you are grounded before starting. To ground yourself, simply touch a metal object that is in contact with the floor for a few seconds.
Was du brauchst
Remove all 15 marked screws on the underside of the laptop using a #0 screwdriver.
x1 9.8mm Screw
x8 5.6mm Screws
x6 5.0mm Screws
Remove the black and grey wires that are connected to the wireless card by pulling away from the card.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
