Einleitung
This guide shows you how to change the light bulb in a globe.
With a plastic meridian like this one, you need to raise the meridian slightly from the North Pole. Use the plastic ring on the north pole to gently press the globe down and pull up the meridian so you lift the little pin,which holdes the globe.
Now you can slowly turn the globe to the side and lift it from the socket at the south pole.
Finally install the globe again by placing it back on the south pole and fixing the meridian on to the north pole.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
