Zum Hauptinhalt wechseln
GoPro HD Hero2 SD Board
Was du brauchst
  1. GoPro HD Hero2 SD Board, Back Cover: Schritt 1, Bild 1 von 2 GoPro HD Hero2 SD Board, Back Cover: Schritt 1, Bild 2 von 2
    • Place your thumb on the indentation in the back case on the side of the GoPro.
    • Gently press down with your thumb and lift the back cover away from the case to remove it.
  2. GoPro HD Hero2 SD Board, Battery: Schritt 2, Bild 1 von 2 GoPro HD Hero2 SD Board, Battery: Schritt 2, Bild 2 von 2
    • Slide a plastic opening tool between the battery and the rear case.
    • Gently pry the battery up and out of the rear case.
  3. GoPro HD Hero2 SD Board: Schritt 3, Bild 1 von 1
    • Remove the battery from the case.
  4. GoPro HD Hero2 SD Board, Rear Case: Schritt 4, Bild 1 von 1
    • Remove the four Phillips #00 screws securing the rear case to the rest of the device:
    • Two 5.5 mm coarse thread screws.
    • Two 4.4 mm fine thread screws.
  5. GoPro HD Hero2 SD Board: Schritt 5, Bild 1 von 2 GoPro HD Hero2 SD Board: Schritt 5, Bild 2 von 2
    • Slide the edge of a plastic opening tool underneath the sticker on the rear cover and gently peel the sticker up.
    • Once you have enough of the sticker peeled up with the plastic opening tool, grab an edge of it with your fingers and pull it off completely.
  6. GoPro HD Hero2 SD Board: Schritt 6, Bild 1 von 2 GoPro HD Hero2 SD Board: Schritt 6, Bild 2 von 2
    • Grasp the rear case and lift it off of the front case.
    • Do not try to completely remove the rear case yet, as it is still attached by the display port ribbon cable.
  7. GoPro HD Hero2 SD Board: Schritt 7, Bild 1 von 2 GoPro HD Hero2 SD Board: Schritt 7, Bild 2 von 2
    • Using a plastic opening tool or your fingernail, flip up the locking tab on the SD board ribbon cable ZIF connector on the motherboard assembly.
    • Be careful that you are prying on the locking tab, and not the connector itself.
    • Use a pair of tweezers to remove the SD board ribbon cable from its connector on the motherboard.
  8. GoPro HD Hero2 SD Board: Schritt 8, Bild 1 von 3 GoPro HD Hero2 SD Board: Schritt 8, Bild 2 von 3 GoPro HD Hero2 SD Board: Schritt 8, Bild 3 von 3
    • Lift the speaker out of the rear case with the tip of a spudger.
    • Remove the rear case.
  9. GoPro HD Hero2 SD Board, SD Board: Schritt 9, Bild 1 von 1
    • Remove the two 5.8 mm Phillips #00 screws securing the SD board cover to the rear case.
  10. GoPro HD Hero2 SD Board: Schritt 10, Bild 1 von 3 GoPro HD Hero2 SD Board: Schritt 10, Bild 2 von 3 GoPro HD Hero2 SD Board: Schritt 10, Bild 3 von 3
    • Turn the rear case over so that the SD card slot is facing you.
    • Use the tip of a spudger to push the bottom of the SD board cover up and out of the rear case.
    • Turn the rear case back over.
    • Lift the SD board cover out of the rear case with the tip of a spudger and remove it.
  11. GoPro HD Hero2 SD Board: Schritt 11, Bild 1 von 2 GoPro HD Hero2 SD Board: Schritt 11, Bild 2 von 2
    • Grasp the SD board ribbon cable gently and pull the SD board out of the rear case.
  12. GoPro HD Hero2 SD Board, SD Board: Schritt 12, Bild 1 von 2 GoPro HD Hero2 SD Board, SD Board: Schritt 12, Bild 2 von 2
    • Use a plastic opening tool or your fingernail to flip up the locking tab on the SD board ribbon cable ZIF connector.
    • Be careful that you are prying up on the locking tab and not the connector itself.
    • Remove the SD board ribbon cable.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
David Hodson
150.493 Reputation
127 Anleitungen geschrieben
Ein Kommentar
Hello,
what you discribe here is not the replacement of the SD board/slot!!
Its the so called Hero Connector!!!!
Can you provide a guide for the replacement of the SD slot?? Or how to fix it if SD card won't go in. Seems something is blocked inside mine.
minne - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 8,731
