Zum Hauptinhalt wechseln
GoPro Hero 3 Silver Expansion Port Replacement
Was du brauchst
  1. GoPro Hero 3 Silver Expansion Port Replacement, Battery: Schritt 1, Bild 1 von 2 GoPro Hero 3 Silver Expansion Port Replacement, Battery: Schritt 1, Bild 2 von 2
    • Pull back on the tab on the back of GoPro to open the battery cover.
  2. GoPro Hero 3 Silver Expansion Port Replacement: Schritt 2, Bild 1 von 1
    • Pull the battery out using the tab.
  3. GoPro Hero 3 Silver Expansion Port Replacement, Expansion Port: Schritt 3, Bild 1 von 2 GoPro Hero 3 Silver Expansion Port Replacement, Expansion Port: Schritt 3, Bild 2 von 2
    • Use the plastic opening tool to remove the faceplate.
    • There is some adhesive and clips so be careful and the faceplate should pop right off.
  4. GoPro Hero 3 Silver Expansion Port Replacement: Schritt 4, Bild 1 von 2 GoPro Hero 3 Silver Expansion Port Replacement: Schritt 4, Bild 2 von 2
    • Now that the faceplate is off, it is time to remove the 4 screws on each corner.
    • Use the T4 tool bit from the iFixit toolkit in order to remove the 4 screws on each corner.
  5. GoPro Hero 3 Silver Expansion Port Replacement: Schritt 5, Bild 1 von 2 GoPro Hero 3 Silver Expansion Port Replacement: Schritt 5, Bild 2 von 2
    • Note: Make sure you remove the door cover of the USB, mini HDMI, and SD port before. Separating the motherboard will be easier.
    • Using the plastic opening tool, slowly pry open the motherboard assembly.
  6. GoPro Hero 3 Silver Expansion Port Replacement: Schritt 6, Bild 1 von 2 GoPro Hero 3 Silver Expansion Port Replacement: Schritt 6, Bild 2 von 2
    • Use the spudger to gently pry off the connector of the housing to the motherboard.
    • You should now have the motherboard assembly and the housing separated.
  7. GoPro Hero 3 Silver Expansion Port Replacement: Schritt 7, Bild 1 von 3 GoPro Hero 3 Silver Expansion Port Replacement: Schritt 7, Bild 2 von 3 GoPro Hero 3 Silver Expansion Port Replacement: Schritt 7, Bild 3 von 3
    • Use the spudger to remove the heat shield tape and detach the image sensor from the motherboard.
    • Using the T4 Torx toolbit, remove the 4 screws that connect the sensor to the lens.
    • Remove the silver connector of the image sensor from the motherboard using the spudger to pry it off.
  8. GoPro Hero 3 Silver Expansion Port Replacement: Schritt 8, Bild 1 von 2 GoPro Hero 3 Silver Expansion Port Replacement: Schritt 8, Bild 2 von 2
    • The media adapter is attached to the motherboard via 3 screws:
    • x1 T4 Torx
    • x2 Phillips #00
    • There is a little silver bracket (in the yellow circle) that is held down by the Phillips #00 screw so be careful not to lose it.
  9. GoPro Hero 3 Silver Expansion Port Replacement: Schritt 9, Bild 1 von 2 GoPro Hero 3 Silver Expansion Port Replacement: Schritt 9, Bild 2 von 2
    • With a little prying, use the spudger to detach the media adapter's connector from the motherboard.
    • Remove the media adapter from the motherboard.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Brian Alvarez
1.439 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 24-7, Lancaster Spring 2015 Mitglied von Cal Poly, Team 24-7, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G7
3 Mitglieder
21 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 17
Insgesamt: 1,855
