Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
In order to replace or fix components in this camera, it is necessary to take of the back and get to the "guts" of the camera. This is because the camera does not come out of the case.
  1. Power off your GoPro before beginning disassembly.
    • Power off your GoPro before beginning disassembly.
    • Unclip the black latch to the camera case and open the case.
  2. Gently pry the back open by inserting a metal spudger between the case and back panel.
    • Gently pry the back open by inserting a metal spudger between the case and back panel.
  3. Nintendo Switch Kits
    Eine schnelle Lösung, um wieder ins Spiel zu kommen
    Switch Kits kaufen
    Switch Kits kaufen
  4. Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
    • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
  5. Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
    • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
  6. Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
    • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
    • Make sure to keep track of these screws as they are very small.
  7. Carefully remove the motherboard and white plastic piece from the case.
    • Carefully remove the motherboard and white plastic piece from the case.
Abschluss
River Drake
981 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 12-2, Lancaster Spring 2015 Mitglied von Cal Poly, Team 12-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G2
4 Mitglieder
12 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 104
