Zum Hauptinhalt wechseln
GoPro Hero Motherboard Replacement
Was du brauchst
  1. GoPro Hero Motherboard Replacement, Casing: Schritt 1, Bild 1 von 1
    • Power off your GoPro before beginning disassembly.
    • Unclip the black latch to the camera case and open the case.
  2. GoPro Hero Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Gently pry the back open by inserting a metal spudger between the case and back panel.
  3. GoPro Hero Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
  4. GoPro Hero Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
  5. GoPro Hero Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
    • Make sure to keep track of these screws as they are very small.
  6. GoPro Hero Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Carefully remove the motherboard and white plastic piece from the case.
  7. GoPro Hero Motherboard Replacement, Motherboard: Schritt 7, Bild 1 von 2 GoPro Hero Motherboard Replacement, Motherboard: Schritt 7, Bild 2 von 2
    • Remove the larger ribbon cable from the daughter board by lifting the black latch and pulling the ribbon cable gently from the socket.
    • Disconnect the smaller ribbon cable leading from the white plastic piece by simply pulling it from the socket.
  8. GoPro Hero Motherboard Replacement: Schritt 8, Bild 1 von 2 GoPro Hero Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Separate the white plastic piece from the motherboard.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Zoe Tuggle
179 Reputation
1 Anleitung geschrieben
Cal Poly, Team 12-2, Lancaster Spring 2015 Mitglied von Cal Poly, Team 12-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G2
4 Mitglieder
18 Anleitungen geschrieben
2 Kommentare zur Anleitung
So after doing all theses steps did it resolve the problem
Anita - Antwort
Thanks so much I really needed this guide.
Thanks, Sam
Sam Liam Matthews - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 15
Letzte 30 Tage: 60
Insgesamt: 10,882
