Einleitung
The image sensor is a vital part of your GoPro. However, don't fear if it has broken, this guide will bring your device back to life!
Was du brauchst
Push the tab on the back of the device left to remove the plate covering the battery.
Insert a plastic opening tool in between the front face plate and the black housing.
Continue to use the plastic opening tool and separate the front face plate from the rest of the device.
Locate the four 8.1mm PH00 screws on the corners of the GoPro and unscrew them using the phillips screwdriver.
Gently remove the motherboard by using a plastic opening tool to pry it out of the housing.
Remove the ribbon cable by carefully flipping the black clip up with the plastic opening tool and pulling the cable out.
Remove the four 4mm PH00 screws attaching the image sensor to the motherboard with your screwdriver.
Pry off the last ribbon cable with a plastic opening tool.
Remove the image sensor from the motherboard.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
