Zum Hauptinhalt wechseln
GoPro Hero5 Black Back Housing Replacement
Was du brauchst
  1. GoPro Hero5 Black Back Housing Replacement, Battery: Schritt 1, Bild 1 von 3 GoPro Hero5 Black Back Housing Replacement, Battery: Schritt 1, Bild 2 von 3 GoPro Hero5 Black Back Housing Replacement, Battery: Schritt 1, Bild 3 von 3
    • While pressing the button on the bottom of the GoPro, slide the battery door to the side to pop it open.
  2. GoPro Hero5 Black Back Housing Replacement: Schritt 2, Bild 1 von 3 GoPro Hero5 Black Back Housing Replacement: Schritt 2, Bild 2 von 3 GoPro Hero5 Black Back Housing Replacement: Schritt 2, Bild 3 von 3
    • Grab the plastic flap on the battery and pull the battery out.
  3. GoPro Hero5 Black Back Housing Replacement, Back Housing: Schritt 3, Bild 1 von 2 GoPro Hero5 Black Back Housing Replacement, Back Housing: Schritt 3, Bild 2 von 2
    • Pull and twist the lens cover right or left until it pops off.
    • The lens cover is secured tightly and might be difficult to twist off.
  4. GoPro Hero5 Black Back Housing Replacement: Schritt 4, Bild 1 von 1
    • This step is not necessary but will make the process of removing the faceplate much easier.
    • Refer to the iOpener instructions for how to heat up and use the iOpener.
    • Apply the heated iOpener to the front of the GoPro for a few minutes to melt the adhesive under the faceplate.
    • The heated iOpener is very hot and can burn your hands. Avoid burns by using towels or gloves to hold the iOpener.
  5. GoPro Hero5 Black Back Housing Replacement: Schritt 5, Bild 1 von 3 GoPro Hero5 Black Back Housing Replacement: Schritt 5, Bild 2 von 3 GoPro Hero5 Black Back Housing Replacement: Schritt 5, Bild 3 von 3
    • Starting with the edges, use the spudger to pry off the faceplate.
    • The faceplate is held down with adhesive and may take a while to get off.
  6. GoPro Hero5 Black Back Housing Replacement: Schritt 6, Bild 1 von 2 GoPro Hero5 Black Back Housing Replacement: Schritt 6, Bild 2 von 2
    • Remove the six T3 Torx screws.
  7. GoPro Hero5 Black Back Housing Replacement: Schritt 7, Bild 1 von 3 GoPro Hero5 Black Back Housing Replacement: Schritt 7, Bild 2 von 3 GoPro Hero5 Black Back Housing Replacement: Schritt 7, Bild 3 von 3
    • Be careful when pulling open the motherboard assembly as it is still connected to the back housing by four cables. The cables may break if stretched.
    • Using the spudger, slowly pry open the motherboard assembly from the LCD side of the GoPro.
  8. GoPro Hero5 Black Back Housing Replacement: Schritt 8, Bild 1 von 3 GoPro Hero5 Black Back Housing Replacement: Schritt 8, Bild 2 von 3 GoPro Hero5 Black Back Housing Replacement: Schritt 8, Bild 3 von 3
    • Use the flat end of a spudger to pry the three ribbon cables connected to the side of the motherboard.
  9. GoPro Hero5 Black Back Housing Replacement: Schritt 9, Bild 1 von 2 GoPro Hero5 Black Back Housing Replacement: Schritt 9, Bild 2 von 2
    • Use the flat end of the spudger to pry the battery housing power cable straight up from its socket on the motherboard.
Abschluss
16 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 18-6, Forte Fall 2016 Mitglied von Cal Poly, Team 18-6, Forte Fall 2016
CPSU-FORTE-F16S18G6
4 Mitglieder
22 Anleitungen geschrieben
2 Kommentare
Where can you get replacement rear screens for this
ociaravella - Antwort
Hi, how i reset firmware in this gopro? I have a problem with a bucle starting and it dont turn on, always restarting.
ISU AREY - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 29
Letzte 30 Tage: 126
Insgesamt: 23,294
