Einleitung
In this guide, you will be removing the lens assembly from the rest of the GoPro. To get to the lens assembly, you must remove almost every other part first. The GoPro Hero5 Black is waterproofed with plenty of adhesives. By completing this guide, you will have to remove the adhesive and your GoPro will no longer be waterproof.
Was du brauchst
While pressing the button on the bottom of the GoPro, slide the battery door to the side to pop it open.
Refer to the iOpener instructions for how to heat up and use the iOpener.
Apply the heated iOpener to the front of the GoPro for a few minutes to melt the adhesive under the faceplate.
Using the spudger, slowly pry open the motherboard assembly from the LCD side of the GoPro.
Use the flat end of a spudger to pry the three ribbon cables connected to the side of the motherboard.
Use the flat end of the spudger to pry the battery housing power cable straight up from its socket on the motherboard.
Use the flat end of the spudger to pry the black cover plate straight up from its socket on the motherboard.
Use the tweezers to pull the ribbon cable connector out of its white socket on the charging assembly board.
Use the flat end of the spudger to pry the charging port ribbon cable connector straight up from its socket on the motherboard.
Remove the charging assembly housing by pulling it straight up off the motherboard.
Remove the two 6mm #000 Phillips screws.
Remove the two 2mm #000 Phillips screws.
Use the flat end of the spudger to pry the lens assembly ribbon cable connector straight up from its socket on the motherboard.
Use the flat end of the spudger to pry the LCD screen ribbon cable connector straight up from its socket on the motherboard.
Remove the 2mm #000 Phillips screws using a #000 Phillips head screwdriver or tool bit.
16 weitere Nutzer:innen haben diese Anleitung absolviert.
7 Kommentare
RageCams has interchangeable lens mod for hero5
why can't You show how the lens is mount to that assembly? That's the point of it... can we change lenses that way or not?
Exactly. Can the actual lens be unscrewed from the mount or it glued / fixed?
contact -
The lens is heavily glued onto the assembly. It would be far easier to replace the entire assembly than trying to remove that glue.
the guy who wrote the guide apparently has never heard of pliers. it comes right out, but no idea what the threading is.
