Zum Hauptinhalt wechseln
GoPro Karma Landing Gear Replacement
Was du brauchst
  1. GoPro Karma Landing Gear Replacement, Battery: Schritt 1, Bild 1 von 1
    • Hook your fingers on the tab and pull out the battery.
  2. GoPro Karma Landing Gear Replacement, Stabilizer: Schritt 2, Bild 1 von 3 GoPro Karma Landing Gear Replacement, Stabilizer: Schritt 2, Bild 2 von 3 GoPro Karma Landing Gear Replacement, Stabilizer: Schritt 2, Bild 3 von 3
    • Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
    • Place the GoPro Karma on a stable surface with the legs folded in and the stabilizer facing towards yourself.
  3. GoPro Karma Landing Gear Replacement: Schritt 3, Bild 1 von 1
    • Remove the stabilizer by pulling the entire stabilizer out of the drone body.
  4. GoPro Karma Landing Gear Replacement, Landing Gear: Schritt 4, Bild 1 von 1
    • Flip the drone upside down with the landing gear out.
    • Remove the four 1.2 cm long hex screws with a Hex 2.0 screwdriver in the four corners of the landing gear
  5. GoPro Karma Landing Gear Replacement: Schritt 5, Bild 1 von 1
    • Push with your thumb and pull up with your fingers to remove the landing gear.
    • Caution: The landing gear is connected by a thin cable so do not pull too far away.
  6. GoPro Karma Landing Gear Replacement: Schritt 6, Bild 1 von 2 GoPro Karma Landing Gear Replacement: Schritt 6, Bild 2 von 2
    • Flip over the landing gear and locate the cable connector.
    • Use your thumbnail to disconnect the cable and free the landing gear.
Abschluss
Jay Ingram
334 Reputation
3 Anleitungen geschrieben
Cal Poly, Team S25-G14, Maness Spring 2018 Mitglied von Cal Poly, Team S25-G14, Maness Spring 2018
CPSU-MANESS-S18S25G14
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 584
