Zum Hauptinhalt wechseln
GoPro Karma Propeller Replacement
  1. GoPro Karma Propeller Replacement, Battery: Schritt 1, Bild 1 von 1
    • Hook your fingers on the tab and pull out the battery.
  2. GoPro Karma Propeller Replacement, Stabilizer: Schritt 2, Bild 1 von 3 GoPro Karma Propeller Replacement, Stabilizer: Schritt 2, Bild 2 von 3 GoPro Karma Propeller Replacement, Stabilizer: Schritt 2, Bild 3 von 3
    • Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
    • Place the GoPro Karma on a stable surface with the legs folded in and the stabilizer facing towards yourself.
  3. GoPro Karma Propeller Replacement: Schritt 3, Bild 1 von 1
    • Remove the stabilizer by pulling the entire stabilizer out of the drone body.
  4. GoPro Karma Propeller Replacement, Propeller: Schritt 4, Bild 1 von 3 GoPro Karma Propeller Replacement, Propeller: Schritt 4, Bild 2 von 3 GoPro Karma Propeller Replacement, Propeller: Schritt 4, Bild 3 von 3
    • Extend the arms and set the drone face up.
    • The front right and back left propellers unscrew clockwise.
    • The front left and back right propellers unscrew counterclockwise.
  5. GoPro Karma Propeller Replacement: Schritt 5, Bild 1 von 2 GoPro Karma Propeller Replacement: Schritt 5, Bild 2 von 2
    • Place the GoPro Karma wrench on the motor.
    • Hold the motor in place with the wrench and unscrew the propeller in the indicated direction.
Abschluss
Jay Ingram
334 Reputation
3 Anleitungen geschrieben
Cal Poly, Team S25-G14, Maness Spring 2018 Mitglied von Cal Poly, Team S25-G14, Maness Spring 2018
CPSU-MANESS-S18S25G14
4 Mitglieder
6 Anleitungen geschrieben
2 Kommentare
You got it the wrong way around, to take them off you need to do the exact opposite to what you say.
michael.woelk - Antwort
hi, i am trying to fix my Karma. I have to remove the propellers but it is like they are stocked.
I try to unscrew the propellers but i can’t remove them.
Do you know what to do in this case?
Davide Negro - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 19
Insgesamt: 1,587
