Einleitung
This guide will show you how to replace the shaft of a golf club. New golf clubs are expensive, so it is very common to buy golf clubs second hand. A second hand club with a worn out, loose, or warped shaft not only deems itself almost useless, but if used, it prevents a danger in the form of the club head flying off of the shaft swing. Oftentimes, it is recommended to take one’s golf club to a specialty repair shop where they can charge you anywhere from $50-$250 to do these simple steps.
Was du brauchst
Use a heat gun to melt the old epoxy holding the club head to the old shaft.
Stabilize the club shaft using a vise grip or the weight of a friend.
With a pair of oven mitts, remove the club head by carefully twisting it from the shaft.
Place the cleaned club head on the new shaft and mark the where the end of the club head reaches on the shaft.
Remove the club head.
Get the epoxy ready by pouring it into a plate.
Use a toothpick to apply epoxy into the part of the club head that goes over the shaft.
Slide the new shaft into the club head.
Wipe off the excess epoxy that squeezes out.
Let the epoxy set overnight for an optimal seal, then it will be ready for use.
Eine weitere Person hat diese Anleitung absolviert.
