Zum Hauptinhalt wechseln
Golf Club Shaft Replacement
Was du brauchst
  1. Golf Club Shaft Replacement, Shaft: Schritt 1, Bild 1 von 1
    • Use a heat gun to melt the old epoxy holding the club head to the old shaft.
    • Caution: Heat guns can get very hot, so use caution when handling them.
  2. Golf Club Shaft Replacement: Schritt 2, Bild 1 von 3 Golf Club Shaft Replacement: Schritt 2, Bild 2 von 3 Golf Club Shaft Replacement: Schritt 2, Bild 3 von 3
    • Stabilize the club shaft using a vise grip or the weight of a friend.
    • With a pair of oven mitts, remove the club head by carefully twisting it from the shaft.
  3. Golf Club Shaft Replacement: Schritt 3, Bild 1 von 2 Golf Club Shaft Replacement: Schritt 3, Bild 2 von 2
    • Clean out the inside of the club head with acetone and a small wire brush.
    • Cleaning the club head will make applying the new epoxy effective.
  4. Golf Club Shaft Replacement: Schritt 4, Bild 1 von 1
    • Place the cleaned club head on the new shaft and mark the where the end of the club head reaches on the shaft.
    • Remove the club head.
  5. Golf Club Shaft Replacement: Schritt 5, Bild 1 von 3 Golf Club Shaft Replacement: Schritt 5, Bild 2 von 3 Golf Club Shaft Replacement: Schritt 5, Bild 3 von 3
    • Take some sand paper and sand the shaft past your mark leading to the tip.
    • A good technique is to wrap the sandpaper around the tip while twisting the hand holding the sandpaper back and forth.
  6. Golf Club Shaft Replacement: Schritt 6, Bild 1 von 3 Golf Club Shaft Replacement: Schritt 6, Bild 2 von 3 Golf Club Shaft Replacement: Schritt 6, Bild 3 von 3
    • Get the epoxy ready by pouring it into a plate.
    • Use a toothpick to apply epoxy into the part of the club head that goes over the shaft.
  7. Golf Club Shaft Replacement: Schritt 7, Bild 1 von 3 Golf Club Shaft Replacement: Schritt 7, Bild 2 von 3 Golf Club Shaft Replacement: Schritt 7, Bild 3 von 3
    • Slide the new shaft into the club head.
    • Wipe off the excess epoxy that squeezes out.
    • Let the epoxy set overnight for an optimal seal, then it will be ready for use.
Ziellinie
Eine weitere Person hat diese Anleitung absolviert.
George Bassili
166 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team S1-G35, Harris Spring 2021 Mitglied von CSU Los Angeles, Team S1-G35, Harris Spring 2021
CSULA-HARRIS-S21S1G35
1 Mitglied
2 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 37
Insgesamt: 1,864
