Zum Hauptinhalt wechseln
Google Cr-48 Chromebook RAM Replacement
Was du brauchst
  1. Google Cr-48 Chromebook RAM Replacement, Battery: Schritt 1, Bild 1 von 3 Google Cr-48 Chromebook RAM Replacement, Battery: Schritt 1, Bild 2 von 3 Google Cr-48 Chromebook RAM Replacement, Battery: Schritt 1, Bild 3 von 3
    • Slide the switch on the bottom of the laptop until the battery pops out.
    • Once the battery pops out, you can remove it.
  2. Google Cr-48 Chromebook RAM Replacement, Remove Rear Rubber Feet: Schritt 2, Bild 1 von 2 Google Cr-48 Chromebook RAM Replacement, Remove Rear Rubber Feet: Schritt 2, Bild 2 von 2
    • Using a pair of tweezers, remove the two rear rubber feet to expose two hidden screws.
  3. Google Cr-48 Chromebook RAM Replacement, Remove Screws: Schritt 3, Bild 1 von 3 Google Cr-48 Chromebook RAM Replacement, Remove Screws: Schritt 3, Bild 2 von 3 Google Cr-48 Chromebook RAM Replacement, Remove Screws: Schritt 3, Bild 3 von 3
    • Remove ten 3 mm screws in the battery compartment using a Phillips #00 screwdriver.
    • Remove two 4.5 mm screws under the rubber feet using a Phillips #00 screwdriver.
  4. Google Cr-48 Chromebook RAM Replacement: Schritt 4, Bild 1 von 3 Google Cr-48 Chromebook RAM Replacement: Schritt 4, Bild 2 von 3 Google Cr-48 Chromebook RAM Replacement: Schritt 4, Bild 3 von 3
    • Starting where the body of the laptop and the laptop screen meet, pry apart the lower case from the rest of the laptop.
    • The case is easier to remove when separating in a clockwise motion, as seen in the pictures.
  5. Google Cr-48 Chromebook RAM Replacement, RAM: Schritt 5, Bild 1 von 3 Google Cr-48 Chromebook RAM Replacement, RAM: Schritt 5, Bild 2 von 3 Google Cr-48 Chromebook RAM Replacement, RAM: Schritt 5, Bild 3 von 3
    • Locate the RAM under a black flap alongside where the laptop screen and device body meet.
  6. Google Cr-48 Chromebook RAM Replacement: Schritt 6, Bild 1 von 3 Google Cr-48 Chromebook RAM Replacement: Schritt 6, Bild 2 von 3 Google Cr-48 Chromebook RAM Replacement: Schritt 6, Bild 3 von 3
    • Using your thumbs, pull the metal arms away from the RAM and then the RAM card should pop up.
  7. Google Cr-48 Chromebook RAM Replacement: Schritt 7, Bild 1 von 2 Google Cr-48 Chromebook RAM Replacement: Schritt 7, Bild 2 von 2
    • Use two fingers to slide the RAM out at the angle that it has been released.
    • Be careful when removing or replacing the RAM sticks that you don't bend the pins or they won't attach properly to the socket.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Athar
365 Reputation
2 Anleitungen geschrieben
CSU Fullerton, Team 2-2, Bruce Fall 2014 Mitglied von CSU Fullerton, Team 2-2, Bruce Fall 2014
CSUF-BRUCE-F14S2G2
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 20
Insgesamt: 1,851
