Zum Hauptinhalt wechseln
Google Home LED Board Replacement
Was du brauchst
  1. Google Home LED Board Replacement, Interconnect Cable: Schritt 1, Bild 1 von 3 Google Home LED Board Replacement, Interconnect Cable: Schritt 1, Bild 2 von 3 Google Home LED Board Replacement, Interconnect Cable: Schritt 1, Bild 3 von 3
    • Removing the lid too quickly could cause you to tear the interconnect cable that attaches the base to the top of the lid.
    • Pull off the Google Home’s magnetically attached base and set it aside.
    • Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
    • After all four screws are out, pop the lid off the device to open the capsule.
  2. Google Home LED Board Replacement: Schritt 2, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Carefully remove the interconnect cable using a pair of tweezers.
  3. Google Home LED Board Replacement, LED Board: Schritt 3, Bild 1 von 2 Google Home LED Board Replacement, LED Board: Schritt 3, Bild 2 von 2
    • Use a metal spudger to pry the LED board away from the lid.
    • This will require some force because there is a strong adhesive layer that keeps the LED board attached to the lid, so don’t worry about being gentle.
    • Remove the LED board.
Abschluss
Gabe Hyun
826 Reputation
4 Anleitungen geschrieben
Cal Poly, Team S24-G11, Maness Spring 2018 Mitglied von Cal Poly, Team S24-G11, Maness Spring 2018
CPSU-MANESS-S18S24G11
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 7
Insgesamt: 751
