Einleitung
A guide to change Google Home Mini USB power port.
Was du brauchst
Remove the rubber bottom as per the Google Home Mini teardown guide.
Remove the four 7mm T6 Torx screws from the bottom.
Using a pair of tweezers, unlatch the Zero Insertion Force (ZIF) fastener that connects the ribbon cable to the board.
9 weitere Nutzer:innen haben diese Anleitung absolviert.
8 Kommentare
Where I can buy micro USB PCB ?
Would like to know this as well disapointing to have an instruction on how to replace a part, but nowere to buy it.
Has anyone had any luck buying a replacement part?
