Zum Hauptinhalt wechseln
Google Home Motherboard Replacement
Was du brauchst
  1. Google Home Motherboard Replacement, Interconnect Cable: Schritt 1, Bild 1 von 3 Google Home Motherboard Replacement, Interconnect Cable: Schritt 1, Bild 2 von 3 Google Home Motherboard Replacement, Interconnect Cable: Schritt 1, Bild 3 von 3
    • Removing the lid too quickly could cause you to tear the interconnect cable that attaches the base to the top of the lid.
    • Pull off the Google Home’s magnetically attached base and set it aside.
    • Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
    • After all four screws are out, pop the lid off the device to open the capsule.
  2. Google Home Motherboard Replacement: Schritt 2, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Carefully remove the interconnect cable using a pair of tweezers.
  3. Google Home Motherboard Replacement, Mute Button Switch: Schritt 3, Bild 1 von 2 Google Home Motherboard Replacement, Mute Button Switch: Schritt 3, Bild 2 von 2
    • Remove the ‘O-ring’ that wraps around the device holding the switch panel in place.
  4. Google Home Motherboard Replacement: Schritt 4, Bild 1 von 2 Google Home Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Using a Torx T6 screwdriver head, unscrew the four black 1.7mm Torx screws.
    • Remove the panel and the mute button switch. If done correctly you should now be able to see the device’s guitar-shaped motherboard.
  5. Google Home Motherboard Replacement, Motherboard: Schritt 5, Bild 1 von 2 Google Home Motherboard Replacement, Motherboard: Schritt 5, Bild 2 von 2
    • Disconnect the foam-padded, red and black cable that connects the motherboard to the sound driver, by squeezing and pulling on the tab
    • Disconnect the orange interconnect cable that connects the bottom of the device to the motherboard by pulling straight out on the orange tab.
  6. Google Home Motherboard Replacement: Schritt 6, Bild 1 von 2 Google Home Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Using a Torx T6 screwdriver head, unscrew the five silver 1.7mm Torx screws keeping the motherboard in place.
    • Remove the motherboard.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team S24-G11, Maness Spring 2018 Mitglied von Cal Poly, Team S24-G11, Maness Spring 2018
CPSU-MANESS-S18S24G11
4 Mitglieder
5 Anleitungen geschrieben
2 Kommentare
Where can one purchase a replacement motherboard?
Jim Pflasterer - Antwort
Most likely the only place to do so would be through contacting Google, as there is no parts sold at retail, only full units
Nick Bergstrom -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 32
Insgesamt: 3,215
