Zum Hauptinhalt wechseln
Google Pixel 2 Display Replacement
Archivierte Anleitung
Diese Anleitung wurde ausschließlich für historische Zwecke erhalten. Verwende die aktualisierte Version dieser Anleitung, um deine Reparatur durchzuführen.
Was du brauchst
  1. Google Pixel 2 Display Replacement, Display: Schritt 1, Bild 1 von 2 Google Pixel 2 Display Replacement, Display: Schritt 1, Bild 2 von 2
    • Heat up the iOpener in the microwave for 30 seconds.
    • Place the iOpener clear-side down on each edge of the phone for approximately 30 seconds.
    • Place the iOpener on top of the screen for an additional 30 seconds.
    • Be careful with the iOpener as it will get extremely hot.
    Frag FixBot
    Kommentar hinzufügen
  2. Google Pixel 2 Display Replacement: Schritt 2, Bild 1 von 3 Google Pixel 2 Display Replacement: Schritt 2, Bild 2 von 3 Google Pixel 2 Display Replacement: Schritt 2, Bild 3 von 3
    • Attach the suction cup to the display by placing it on top of the display and pushing down on the top of the cup until it is flat.
    • Separate the display and the device by inserting the plastic opening tool between them and sliding the plastic opening tool along the perimeter of the display.
    • It is normal to hear popping noises as the plastic opening tool breaks the connection between the display and the device.
    • Remove the display from the device by grabbing the ring of the suction cup and pulling up.
    Frag FixBot
  3. Google Pixel 2 Display Replacement: Schritt 3, Bild 1 von 3 Google Pixel 2 Display Replacement: Schritt 3, Bild 2 von 3 Google Pixel 2 Display Replacement: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Remove the T4 4.0-mm screws from the latch under the display by turning the screwdriver counterclockwise.
    • Pull the latch off of the device by grabbing it with the tweezers and pulling up.
    Frag FixBot
  4. Google Pixel 2 Display Replacement: Schritt 4, Bild 1 von 1
    • Remove the connector underneath the latch by grabbing it with the tweezers and lifting up.
    • It is normal to hear a popping noise during this step.
    • When reassembling, simply use your finger to pop this piece back into place by pushing it down into the device.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team S18-G5, Livingston Winter 2018 Mitglied von Cal Poly, Team S18-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G5
4 Mitglieder
23 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 32
Insgesamt: 1,361
