Einleitung
Since the display acts as a barrier to the hardware, it is important to remove it before replacing other components. Due to its simplicity, this guide only requires a few steps and tools to remove the display.
Was du brauchst
Heat up the iOpener in the microwave for 30 seconds.
Place the iOpener clear-side down on each edge of the phone for approximately 30 seconds.
Place the iOpener on top of the screen for an additional 30 seconds.
Attach the suction cup to the display by placing it on top of the display and pushing down on the top of the cup until it is flat.
Separate the display and the device by inserting the plastic opening tool between them and sliding the plastic opening tool along the perimeter of the display.
Remove the display from the device by grabbing the ring of the suction cup and pulling up.
Remove the connector underneath the latch by grabbing it with the tweezers and lifting up.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
