Einleitung
This guide is a pre-requisite step for other Pixel 3a XL guides. It describes the process of removing the midframe between the screen and the rest of the phone’s internals.
Was du brauchst
In diesem Schritt verwendetes Werkzeug:Magnetic Project Mat$19.95
Remove the following 4.3mm screws:
14 silver T3 Torx screws
2 black T3 Torx screws
Insert an opening pick into the seam along the bottom of the phone.
Slide the pick along the seam to release the clips holding the midframe to the rest of the phone.
Slide the opening pick along the left and right edges of the phone to release the midframe clips there.
Lift up the bottom edge of the midframe but don’t completely remove it yet. The midframe is still connected to the phone by a fragile cable.
Use a spudger to pry up and detach the proximity sensor cable from the motherboard.
This takes a bit of patience and finesse. Once you have the connector aligned, you can also use a finger to gently press the connector onto the socket.
