Zum Hauptinhalt wechseln
Google Pixel 4 XL Screen Replacement
Was du brauchst
  1. Google Pixel 4 XL Screen Replacement, Remove the SIM card tray: Schritt 1, Bild 1 von 3 Google Pixel 4 XL Screen Replacement, Remove the SIM card tray: Schritt 1, Bild 2 von 3 Google Pixel 4 XL Screen Replacement, Remove the SIM card tray: Schritt 1, Bild 3 von 3
    • Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the left edge of the phone.
    • Press firmly to eject the tray.
    • Remove the SIM card tray.
  2. Google Pixel 4 XL Screen Replacement, Heat the back panel glass: Schritt 2, Bild 1 von 1
    • Prepare an iOpener and apply it to the bottom edge of the back panel for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  3. Google Pixel 4 XL Screen Replacement, Apply a suction cup: Schritt 3, Bild 1 von 2 Google Pixel 4 XL Screen Replacement, Apply a suction cup: Schritt 3, Bild 2 von 2
    • Apply a suction cup to the heated edge of the back panel by pressing down on it to create suction, as close to the edge as possible.
    • If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken panel.
  4. Google Pixel 4 XL Screen Replacement, Insert an opening pick: Schritt 4, Bild 1 von 2 Google Pixel 4 XL Screen Replacement, Insert an opening pick: Schritt 4, Bild 2 von 2
    • Pull up on the suction cup with strong, steady force to create a gap between the back panel and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
  5. Google Pixel 4 XL Screen Replacement, Begin to slice the adhesive: Schritt 5, Bild 1 von 3 Google Pixel 4 XL Screen Replacement, Begin to slice the adhesive: Schritt 5, Bild 2 von 3 Google Pixel 4 XL Screen Replacement, Begin to slice the adhesive: Schritt 5, Bild 3 von 3
    • Slide the opening pick across the bottom towards the left corner to slice the adhesive.
    • With the pick still inserted, slide it from the bottom left corner over to the bottom right corner to completely slice the bottom side adhesive.
    • Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  6. Google Pixel 4 XL Screen Replacement, Slice the lefthand-side adhesive: Schritt 6, Bild 1 von 1
    • Prepare an iOpener and apply it on the left edge of the phone for one minute.
  7. Google Pixel 4 XL Screen Replacement: Schritt 7, Bild 1 von 2 Google Pixel 4 XL Screen Replacement: Schritt 7, Bild 2 von 2
    • Insert a second opening pick underneath the back panel directly over the charge port.
    • Slide the opening pick to the bottom left corner of the phone.
  8. Google Pixel 4 XL Screen Replacement: Schritt 8, Bild 1 von 2 Google Pixel 4 XL Screen Replacement: Schritt 8, Bild 2 von 2
    • Slide the opening pick around the bottom left corner and across the left side of the phone to slice the adhesive.
    • The adhesive can be very gummy. Push the pick in and out in a sawing motion to help with slicing.
    • Stop when you reach the top left corner, near the camera, and leave the pick inserted.
  9. Google Pixel 4 XL Screen Replacement, Slice righthand-side adhesive: Schritt 9, Bild 1 von 1
    • Prepare an iOpener and apply it on the right edge of the phone for one minute.
  10. Google Pixel 4 XL Screen Replacement: Schritt 10, Bild 1 von 3 Google Pixel 4 XL Screen Replacement: Schritt 10, Bild 2 von 3 Google Pixel 4 XL Screen Replacement: Schritt 10, Bild 3 von 3
    • With the first two opening picks still in place, insert a third pick on the lower part of the righthand side.
    • Slide the opening pick up towards the top of the phone, slicing the right side's adhesive.
    • Stop when you reach the top right corner, and leave the pick inserted.
  11. Google Pixel 4 XL Screen Replacement, Slice the top-side adhesive: Schritt 11, Bild 1 von 2 Google Pixel 4 XL Screen Replacement, Slice the top-side adhesive: Schritt 11, Bild 2 von 2
    • Slide the third opening pick around the top right corner and across the top side of the phone, slicing the final strip of adhesive.
  12. Google Pixel 4 XL Screen Replacement, Lift up the back panel: Schritt 12, Bild 1 von 3 Google Pixel 4 XL Screen Replacement, Lift up the back panel: Schritt 12, Bild 2 von 3 Google Pixel 4 XL Screen Replacement, Lift up the back panel: Schritt 12, Bild 3 von 3
    • Once you have sliced around the perimeter of the phone, carefully lift the right edge of the back cover, opening it like a book.
    • Do not try to pull the panel all the way off yet, as it is still connected to the phone.
  13. Google Pixel 4 XL Screen Replacement: Schritt 13, Bild 1 von 2 Google Pixel 4 XL Screen Replacement: Schritt 13, Bild 2 von 2
    • Continue swinging open the back panel until you can rest it on the left edge the phone, being careful not to put any stress on the attached ribbon cable.
    • During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
  14. Google Pixel 4 XL Screen Replacement, Disconnect the battery: Schritt 14, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Magnetic Project Mat
    $19.95
    • Remove the four T3 Torx screws securing the battery connector shield:
    • One 1.8 mm screw
    • One 4.1 mm screw
    • One 4.4 mm shouldered screw
    • One 4.0 mm shouldered screw
  15. Google Pixel 4 XL Screen Replacement: Schritt 15, Bild 1 von 2 Google Pixel 4 XL Screen Replacement: Schritt 15, Bild 2 von 2
    • Use a pair of tweezers to remove the battery connector shield.
  16. Google Pixel 4 XL Screen Replacement: Schritt 16, Bild 1 von 2 Google Pixel 4 XL Screen Replacement: Schritt 16, Bild 2 von 2
    • Whenever you use the spudger near the battery, be very careful not to puncture the battery.
    • Using the pointed end of a spudger, pry the battery connector straight up from the motherboard to disconnect the battery.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  17. Google Pixel 4 XL Screen Replacement: Schritt 17, Bild 1 von 2 Google Pixel 4 XL Screen Replacement: Schritt 17, Bild 2 von 2
    • Using the flat end of a spudger, gently fold the battery cable over so it doesn't accidentally make contact during the rest of your repairs.
  18. Google Pixel 4 XL Screen Replacement, Disconnect the back panel connector: Schritt 18, Bild 1 von 1
    • Use a T3 Torx driver to remove the two 4.1 mm screws securing the back panel connector cover.
  19. Google Pixel 4 XL Screen Replacement: Schritt 19, Bild 1 von 2 Google Pixel 4 XL Screen Replacement: Schritt 19, Bild 2 von 2
    • Use a pair of tweezers to remove the back panel connector cover.
  20. Google Pixel 4 XL Screen Replacement: Schritt 20, Bild 1 von 2 Google Pixel 4 XL Screen Replacement: Schritt 20, Bild 2 von 2
    • Using the pointed end of a spudger, pry up and disconnect the back panel connector.
  21. Google Pixel 4 XL Screen Replacement, Remove the back panel: Schritt 21, Bild 1 von 1
    • Remove the back panel.
    • During reassembly, follow this guide to install custom-cut adhesives for your device.
    • Follow this guide if you are using a pre-cut adhesive card.
  22. Google Pixel 4 XL Screen Replacement, Remove the battery's adhesive pull tabs: Schritt 22, Bild 1 von 2 Google Pixel 4 XL Screen Replacement, Remove the battery's adhesive pull tabs: Schritt 22, Bild 2 von 2
    • Use blunt tweezers to lift up the battery adhesive pull tabs so you can more easily grip them with your fingers.
    • The battery is held in place with three separate stretch adhesive strips, which are connected to a single black pull tab. You can try to pull all three strips out together, but it is easier to cut the black pull tab where it is notched and pull each strip out individually.
  23. Google Pixel 4 XL Screen Replacement: Schritt 23, Bild 1 von 2 Google Pixel 4 XL Screen Replacement: Schritt 23, Bild 2 von 2
    • Pull on the black pull tab at a shallow angle with steady force. When the adhesive grows long, roll it around a spudger and continue pulling.
    • Continue firmly pulling up on the adhesive strip with constant force, spinning the spudger every so often to keep the exposed section of the pull tab as short as possible.
    • This may take a lot of force.
    • These adhesive pull tabs are very prone to snapping in half during this process. Try pulling as slowly as possible.
    • If the adhesive pull tabs are not stretching, you can fill a plastic dropper or syringe with high concentration isopropyl alcohol and apply a few drops under the left edge of the battery. Give the alcohol a minute to weaken the battery adhesive.
    • Continue this process for each of the three pull tabs, until all are either out or have snapped in half.
  24. Google Pixel 4 XL Screen Replacement, Remove the battery: Schritt 24, Bild 1 von 3 Google Pixel 4 XL Screen Replacement, Remove the battery: Schritt 24, Bild 2 von 3 Google Pixel 4 XL Screen Replacement, Remove the battery: Schritt 24, Bild 3 von 3
    • If the battery tabs snapped during removal, insert an opening pick on the upper right edge of the battery, slicing the adhesive underneath.
    • Even if you successfully removed all three adhesive pull tabs, using an opening pick to dislodge the battery may be helpful.
    • Don't insert the opening pick on or anywhere below the grip sensor cable, as the pick can damage the charge port flex cable located underneath the battery.
  25. Google Pixel 4 XL Screen Replacement: Schritt 25, Bild 1 von 2 Google Pixel 4 XL Screen Replacement: Schritt 25, Bild 2 von 2
    Tesa 61395 Tape
    $8.95
    • Don't reuse the battery if it has been deformed or damaged, as doing so is a potential safety hazard. Replace it with a new battery.
    • Lift the battery up, away from the phone to remove it.
    • To install a replacement battery:
    • Remove any remaining adhesive from the battery well.
    • If you're using stretch release adhesive, apply them onto the battery. Otherwise, apply some double-sided tape, or pre-cut adhesive strips in the phone's battery well, being careful not to cover the charge port flex cable. Peel away any tape liners to expose the adhesive.
    • Temporarily re-connect the battery's connector to the motherboard socket. This ensures that the battery is properly positioned.
    • Lay the battery in place and press firmly.
    • Disconnect the battery connector from its motherboard socket and resume re-assembly.
  26. Google Pixel 4 XL Screen Replacement, Remove the rear-facing camera cover: Schritt 26, Bild 1 von 1
    • Use your T3 Torx screwdriver to remove the following screws securing the rear-facing camera connector cover:
    • One 2.7 mm screw
    • One 4.1 mm screw
    • One 4.2 mm screw
  27. Google Pixel 4 XL Screen Replacement: Schritt 27, Bild 1 von 2 Google Pixel 4 XL Screen Replacement: Schritt 27, Bild 2 von 2
    • Use a pair of tweezers to remove the rear-facing camera connector cover.
  28. Google Pixel 4 XL Screen Replacement: Schritt 28, Bild 1 von 1
    • Use your T3 Torx screwdriver to remove the following screws securing the front-facing camera connector cover:
    • One 4.1 mm screw
    • One 4.1 mm shouldered screw
  29. Google Pixel 4 XL Screen Replacement: Schritt 29, Bild 1 von 3 Google Pixel 4 XL Screen Replacement: Schritt 29, Bild 2 von 3 Google Pixel 4 XL Screen Replacement: Schritt 29, Bild 3 von 3
    • Use a pair of tweezers to remove the front-facing camera connector cover.
  30. Google Pixel 4 XL Screen Replacement, Disconnect the camera and sensor connectors: Schritt 30, Bild 1 von 3 Google Pixel 4 XL Screen Replacement, Disconnect the camera and sensor connectors: Schritt 30, Bild 2 von 3 Google Pixel 4 XL Screen Replacement, Disconnect the camera and sensor connectors: Schritt 30, Bild 3 von 3
    • Use the pointed end of your spudger to pry the camera and sensor connectors straight up from the motherboard to disconnect them.
  31. Google Pixel 4 XL Screen Replacement: Schritt 31, Bild 1 von 2 Google Pixel 4 XL Screen Replacement: Schritt 31, Bild 2 von 2
    • Use the pointed end of your spudger to pry up and disconnect the remaining sensor connector from the motherboard.
    • This cable is secured to the phone with some light adhesive.
  32. Google Pixel 4 XL Screen Replacement, Remove the front camera and sensor assembly: Schritt 32, Bild 1 von 1
    • Use your T3 Torx screwdriver to remove the following screws from the front camera and sensor assembly:
    • Two 2.7 mm screws
    • One 3.1 mm screw
  33. Google Pixel 4 XL Screen Replacement: Schritt 33, Bild 1 von 3 Google Pixel 4 XL Screen Replacement: Schritt 33, Bild 2 von 3 Google Pixel 4 XL Screen Replacement: Schritt 33, Bild 3 von 3
    • Use a pair of tweezers to remove the front camera and sensor assembly.
  34. Google Pixel 4 XL Screen Replacement, Remove the screws securing the display connector cover: Schritt 34, Bild 1 von 1
    • Use your T3 Torx driver to remove the four 3.5 mm screws securing the display connector cover.
  35. Google Pixel 4 XL Screen Replacement, Remove the display connector cover: Schritt 35, Bild 1 von 2 Google Pixel 4 XL Screen Replacement, Remove the display connector cover: Schritt 35, Bild 2 von 2
    • Use a pair of tweezers to remove the display connector cover.
  36. Google Pixel 4 XL Screen Replacement, Disconnect the display connector: Schritt 36, Bild 1 von 2 Google Pixel 4 XL Screen Replacement, Disconnect the display connector: Schritt 36, Bild 2 von 2
    • Use the flat end of a spudger to disconnect the display connector from the motherboard.
  37. Google Pixel 4 XL Screen Replacement, Remove the motherboard screw: Schritt 37, Bild 1 von 1
    • Use your T3 Torx driver to remove the 2.7 mm screw securing the motherboard to the frame.
  38. Google Pixel 4 XL Screen Replacement, Disconnect the motherboard press connectors: Schritt 38, Bild 1 von 3 Google Pixel 4 XL Screen Replacement, Disconnect the motherboard press connectors: Schritt 38, Bild 2 von 3 Google Pixel 4 XL Screen Replacement, Disconnect the motherboard press connectors: Schritt 38, Bild 3 von 3
    • Use the pointed end of your spudger to disconnect the three side button and rear-facing camera connectors from the motherboard.
  39. Google Pixel 4 XL Screen Replacement: Schritt 39, Bild 1 von 2 Google Pixel 4 XL Screen Replacement: Schritt 39, Bild 2 von 2
    • Use the pointed end of your spudger to disconnect the earpiece speaker from the motherboard.
  40. Google Pixel 4 XL Screen Replacement: Schritt 40, Bild 1 von 3 Google Pixel 4 XL Screen Replacement: Schritt 40, Bild 2 von 3 Google Pixel 4 XL Screen Replacement: Schritt 40, Bild 3 von 3
    • Use the pointed end of your spudger to disconnect the two grip sensor connectors from the motherboard.
    • Use the flat end of your spudger to disconnect the charge port connector from the motherboard.
  41. Google Pixel 4 XL Screen Replacement, Disconnect the antennas: Schritt 41, Bild 1 von 3 Google Pixel 4 XL Screen Replacement, Disconnect the antennas: Schritt 41, Bild 2 von 3 Google Pixel 4 XL Screen Replacement, Disconnect the antennas: Schritt 41, Bild 3 von 3
    • Use a pair of tweezers to disconnect the two coaxial antenna connectors from the motherboard.
  42. Google Pixel 4 XL Screen Replacement, Remove the motherboard: Schritt 42, Bild 1 von 2 Google Pixel 4 XL Screen Replacement, Remove the motherboard: Schritt 42, Bild 2 von 2
    • Use your spudger to pry up and loosen the top edge of the motherboard.
  43. Google Pixel 4 XL Screen Replacement: Schritt 43, Bild 1 von 3 Google Pixel 4 XL Screen Replacement: Schritt 43, Bild 2 von 3 Google Pixel 4 XL Screen Replacement: Schritt 43, Bild 3 von 3
    • Slowly lift out the motherboard, being careful not to snag any ribbon cable connectors.
    • The rear-facing camera module connectors loop around the motherboard, and the camera module is not secured to the phone, so it may lift out with the motherboard during this step.
    • Completely remove the motherboard.
    • When reinstalling the motherboard, check that no ribbon cable connectors are caught underneath.
  44. Google Pixel 4 XL Screen Replacement, Remove the rear cameras: Schritt 44, Bild 1 von 2 Google Pixel 4 XL Screen Replacement, Remove the rear cameras: Schritt 44, Bild 2 von 2
    • Use a pair of tweezers to remove the rear-facing camera module.
  45. Google Pixel 4 XL Screen Replacement, Remove the earpiece module: Schritt 45, Bild 1 von 1
    • Use a T3 Torx driver to remove the 2 mm screw securing the antenna connector board board to the phone.
  46. Google Pixel 4 XL Screen Replacement: Schritt 46, Bild 1 von 3 Google Pixel 4 XL Screen Replacement: Schritt 46, Bild 2 von 3 Google Pixel 4 XL Screen Replacement: Schritt 46, Bild 3 von 3
    • Using the pointed end of a spudger, slide the board slightly to the side, away from the top of the phone.
    • Do not attempt to entirely remove this board; it's still connected to the earpiece speaker.
  47. Google Pixel 4 XL Screen Replacement: Schritt 47, Bild 1 von 3 Google Pixel 4 XL Screen Replacement: Schritt 47, Bild 2 von 3 Google Pixel 4 XL Screen Replacement: Schritt 47, Bild 3 von 3
    • Use the pointed end of your spudger to peel the microphone away from the light adhesive securing it to the phone.
    • Ensure the microphone is completely detached from the top frame before continuing to the next step.
  48. Google Pixel 4 XL Screen Replacement: Schritt 48, Bild 1 von 2 Google Pixel 4 XL Screen Replacement: Schritt 48, Bild 2 von 2
    • Use the flat end of your spudger to pry the earpiece module away from the phone's midframe.
    • The earpiece module is attached with some light adhesive, and should come up without too much force.
  49. Google Pixel 4 XL Screen Replacement: Schritt 49, Bild 1 von 3 Google Pixel 4 XL Screen Replacement: Schritt 49, Bild 2 von 3 Google Pixel 4 XL Screen Replacement: Schritt 49, Bild 3 von 3
    • Use a pair of tweezers or your fingers to pull the earpiece module away from the light adhesive holding it to the phone's top frame.
    • Remove the earpiece module.
  50. Google Pixel 4 XL Screen Replacement: Schritt 50, Bild 1 von 2 Google Pixel 4 XL Screen Replacement: Schritt 50, Bild 2 von 2
    • Use a pair of tweezers to remove the earpiece speaker and Soli motion sensor assembly.
  51. Google Pixel 4 XL Screen Replacement, Remove the loudspeaker: Schritt 51, Bild 1 von 1
    • Use your T3 Torx screwdriver to remove the three screws securing the loudspeaker:
    • One 4.1 mm screw
    • One 2.7 mm screw
  52. Google Pixel 4 XL Screen Replacement: Schritt 52, Bild 1 von 3 Google Pixel 4 XL Screen Replacement: Schritt 52, Bild 2 von 3 Google Pixel 4 XL Screen Replacement: Schritt 52, Bild 3 von 3
    • Use a pair of tweezers to lift the loudspeaker up and away from the frame.
    • Remove the loudspeaker.
  53. Google Pixel 4 XL Screen Replacement, Isolate the charging assembly: Schritt 53, Bild 1 von 2 Google Pixel 4 XL Screen Replacement, Isolate the charging assembly: Schritt 53, Bild 2 von 2
    • Use the pointed end of your spudger to disconnect the two antenna press connectors from the charging assembly.
  54. Google Pixel 4 XL Screen Replacement: Schritt 54, Bild 1 von 3 Google Pixel 4 XL Screen Replacement: Schritt 54, Bild 2 von 3 Google Pixel 4 XL Screen Replacement: Schritt 54, Bild 3 von 3
    • Disconnect the antenna press connectors from the charging assembly.
  55. Google Pixel 4 XL Screen Replacement, Remove the charging assembly: Schritt 55, Bild 1 von 3 Google Pixel 4 XL Screen Replacement, Remove the charging assembly: Schritt 55, Bild 2 von 3 Google Pixel 4 XL Screen Replacement, Remove the charging assembly: Schritt 55, Bild 3 von 3
    • Peel back the ribbon cable until it is fully separated from the frame.
    • The ribbon cable is secured to the frame with some light adhesive.
    • Remove the charging assembly.
  56. Google Pixel 4 XL Screen Replacement, Remove the microphone assembly: Schritt 56, Bild 1 von 1
    • Use a T3 Torx driver to remove the 3 mm screw securing the bottom microphone assembly to the bottom right corner of the frame.
  57. Google Pixel 4 XL Screen Replacement: Schritt 57, Bild 1 von 3 Google Pixel 4 XL Screen Replacement: Schritt 57, Bild 2 von 3 Google Pixel 4 XL Screen Replacement: Schritt 57, Bild 3 von 3
    • Insert the pointed end of a spudger into the divot between the microphone assembly and the frame.
    • Slide the pointed end of the spudger from left to right, separating the microphone assembly and the frame.
    • Remove the microphone assembly using your fingers or a pair of tweezers.
  58. Google Pixel 4 XL Screen Replacement: Schritt 58, Bild 1 von 3 Google Pixel 4 XL Screen Replacement: Schritt 58, Bild 2 von 3 Google Pixel 4 XL Screen Replacement: Schritt 58, Bild 3 von 3
    • Use a T3 Torx driver to remove the two screws securing the antenna to the frame:
    • One 2 mm screw on the left side of the frame
    • One 2 mm screw on the bottom side of the frame
  59. Google Pixel 4 XL Screen Replacement, Remove the antenna: Schritt 59, Bild 1 von 2 Google Pixel 4 XL Screen Replacement, Remove the antenna: Schritt 59, Bild 2 von 2
    • Insert the pointed end of a spudger underneath the antenna's ribbon cable and gently pry up to peel the cable from the frame.
    • The antenna's ribbon cable is secured to the frame with some light adhesive.
    • Remove the antenna.
  60. Google Pixel 4 XL Screen Replacement, Remove the vibration motor: Schritt 60, Bild 1 von 2 Google Pixel 4 XL Screen Replacement, Remove the vibration motor: Schritt 60, Bild 2 von 2
    • Use a pair of pliers to firmly grip the vibration motor near the bottom right of the device.
    • Pull straight up with steady force until the motor separates from the frame.
    • Grip the vibration motor by the side opposite its cable and be sure not to damage the cables covering the rest of the motor.
  61. Google Pixel 4 XL Screen Replacement, Only the screen remains: Schritt 61, Bild 1 von 1
    • You're now left with the screen.
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
4 weitere Personen haben diese Anleitung absolviert.
Clay Kim
12.671 Reputation
21 Anleitungen geschrieben
1 Kommentar zur Anleitung
Can you also add a recommendation to cover cameras right after lifting up the back panel so they wont get dirty?
Josh - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 27
Letzte 30 Tage: 136
Insgesamt: 9,491
