Zum Hauptinhalt wechseln
Google Pixel 9 Motherboard Replacement
Was du brauchst
  1. Google Pixel 9 Motherboard Replacement, Prepare your Pixel for disassembly: Schritt 1, Bild 1 von 3 Google Pixel 9 Motherboard Replacement, Prepare your Pixel for disassembly: Schritt 1, Bild 2 von 3 Google Pixel 9 Motherboard Replacement, Prepare your Pixel for disassembly: Schritt 1, Bild 3 von 3
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Completely power off your phone.
    • Press the power and volume up buttons at the same time to bring up the shutdown menu.
  2. Google Pixel 9 Motherboard Replacement, Adhesive information: Schritt 2, Bild 1 von 3 Google Pixel 9 Motherboard Replacement, Adhesive information: Schritt 2, Bild 2 von 3 Google Pixel 9 Motherboard Replacement, Adhesive information: Schritt 2, Bild 3 von 3
    • Adhesive secures the perimeter of the back glass to the frame.
    • When separating the adhesive, don't insert your tool more than 3 mm under the back glass to avoid damaging the internal components.
    • To help, measure and mark 3 mm from the tip of an opening pick with a permanent marker.
    • If your screen or back glass is badly cracked, a suction cup may not perfectly adhere.
    • Lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier. Ensure there's a smooth area near the bottom edge that's large and smooth enough for a suction cup to stick to.
  3. Google Pixel 9 Motherboard Replacement, Apply a suction handle: Schritt 3, Bild 1 von 2 Google Pixel 9 Motherboard Replacement, Apply a suction handle: Schritt 3, Bild 2 von 2
    • Place a suction handle at the bottom edge of the back glass, as close to the edge as possible.
    • Push down to attach the suction cup.
  4. Google Pixel 9 Motherboard Replacement, Insert an opening pick: Schritt 4, Bild 1 von 3 Google Pixel 9 Motherboard Replacement, Insert an opening pick: Schritt 4, Bild 2 von 3 Google Pixel 9 Motherboard Replacement, Insert an opening pick: Schritt 4, Bild 3 von 3
    • Pull up on the suction handle with strong, steady force to create a small gap under the back glass.
    • Insert the tip of an opening pick into the gap.
  5. Google Pixel 9 Motherboard Replacement, Separate the back glass adhesive: Schritt 5, Bild 1 von 3 Google Pixel 9 Motherboard Replacement, Separate the back glass adhesive: Schritt 5, Bild 2 von 3 Google Pixel 9 Motherboard Replacement, Separate the back glass adhesive: Schritt 5, Bild 3 von 3
    • Slide the opening pick back and forth along the bottom edge to separate the adhesive securing it.
    • Remember: don't insert the opening pick deeper than 3 mm.
  6. Google Pixel 9 Motherboard Replacement: Schritt 6, Bild 1 von 3 Google Pixel 9 Motherboard Replacement: Schritt 6, Bild 2 von 3 Google Pixel 9 Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Slide the opening pick around the perimeter of the phone, slicing the rest of the adhesive.
  7. Google Pixel 9 Motherboard Replacement: Schritt 7, Bild 1 von 3 Google Pixel 9 Motherboard Replacement: Schritt 7, Bild 2 von 3 Google Pixel 9 Motherboard Replacement: Schritt 7, Bild 3 von 3
    • With most of the adhesive separated, lightly twist the opening pick at the bottom edge to lift the back glass up until you can grip it with your fingers.
    • Use the opening pick to separate any remaining sections of adhesive securing the back glass.
  8. Google Pixel 9 Motherboard Replacement, Remove the back glass: Schritt 8, Bild 1 von 1
    • Remove the back glass.
    • During reassembly:
    • Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
    • Follow this guide to apply new adhesive and install your back glass.
  9. Google Pixel 9 Motherboard Replacement, Remove the upper board cover: Schritt 9, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    FixMat
    $36.95
    • While the Pixel 9 uses Torx Plus screws, standard Torx bits also work. Make sure to apply constant, downward force to prevent stripping.
    • Use a 3IP Torx Plus driver to remove the single 5.4 mm‑long screw securing the upper board cover.
  10. Google Pixel 9 Motherboard Replacement: Schritt 10, Bild 1 von 2 Google Pixel 9 Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Use a pair of tweezers to remove the upper board cover.
  11. Google Pixel 9 Motherboard Replacement, Remove the midframe: Schritt 11, Bild 1 von 1
    • Use a 3IP Torx driver to remove the five screws securing the midframe and wireless charging coil:
    • Four 5.4 mm-long screws
    • One 2.2 mm-long screw
  12. Google Pixel 9 Motherboard Replacement, Peel up the flash cable: Schritt 12, Bild 1 von 2 Google Pixel 9 Motherboard Replacement, Peel up the flash cable: Schritt 12, Bild 2 von 2
    • Use a pair of tweezers to peel the flash cable off of the metal midframe.
  13. Google Pixel 9 Motherboard Replacement, Remove the midframe: Schritt 13, Bild 1 von 2 Google Pixel 9 Motherboard Replacement, Remove the midframe: Schritt 13, Bild 2 von 2
    • Remove the midframe, wireless charging coil, and NFC assembly.
  14. Google Pixel 9 Motherboard Replacement, Disconnect the battery: Schritt 14, Bild 1 von 2 Google Pixel 9 Motherboard Replacement, Disconnect the battery: Schritt 14, Bild 2 von 2
    • Use the tip of a spudger to pry up and disconnect the battery connector.
  15. Google Pixel 9 Motherboard Replacement, Disconnect the 5G mmWave antenna: Schritt 15, Bild 1 von 3 Google Pixel 9 Motherboard Replacement, Disconnect the 5G mmWave antenna: Schritt 15, Bild 2 von 3 Google Pixel 9 Motherboard Replacement, Disconnect the 5G mmWave antenna: Schritt 15, Bild 3 von 3
    • Use the tip of a spudger to pry up and disconnect the 5G mmWave antenna's press connector.
  16. Google Pixel 9 Motherboard Replacement, Remove the 5G mmWave antenna: Schritt 16, Bild 1 von 3 Google Pixel 9 Motherboard Replacement, Remove the 5G mmWave antenna: Schritt 16, Bild 2 von 3 Google Pixel 9 Motherboard Replacement, Remove the 5G mmWave antenna: Schritt 16, Bild 3 von 3
    • Remove the 5G mmWave antenna.
    • A small flex cable attaches to the back of the antenna with a press connector. You may need to reconnect it if it falls off.
    • During reassembly, insert the antenna so it's between the frame and the small metal bracket near the top right corner.
  17. Google Pixel 9 Motherboard Replacement, Remove the antenna board cover: Schritt 17, Bild 1 von 1
    • Use a 3IP Torx Plus driver to remove the 5.4 mm-long screw securing the antenna board cover.
  18. Google Pixel 9 Motherboard Replacement: Schritt 18, Bild 1 von 1
    • Use a pair of tweezers to remove the antenna board cover.
  19. Google Pixel 9 Motherboard Replacement, Disconnect the autofocus cable: Schritt 19, Bild 1 von 2 Google Pixel 9 Motherboard Replacement, Disconnect the autofocus cable: Schritt 19, Bild 2 von 2
    • Use the tip of a spudger to pry up and disconnect the autofocus connector from the motherboard.
  20. Google Pixel 9 Motherboard Replacement, Disconnect the antenna cable: Schritt 20, Bild 1 von 2 Google Pixel 9 Motherboard Replacement, Disconnect the antenna cable: Schritt 20, Bild 2 von 2
    • Insert one arm of a pair of angled tweezers under the metal neck of the antenna board's coaxial antenna cable.
    • Lift straight up to disconnect the antenna.
  21. Google Pixel 9 Motherboard Replacement, Disconnect the front camera: Schritt 21, Bild 1 von 2 Google Pixel 9 Motherboard Replacement, Disconnect the front camera: Schritt 21, Bild 2 von 2
    • Use the tip of a spudger to pry up and disconnect the front camera press connector.
  22. Google Pixel 9 Motherboard Replacement, Disconnect the interconnect cables: Schritt 22, Bild 1 von 3 Google Pixel 9 Motherboard Replacement, Disconnect the interconnect cables: Schritt 22, Bild 2 von 3 Google Pixel 9 Motherboard Replacement, Disconnect the interconnect cables: Schritt 22, Bild 3 von 3
    • Use the tip of a spudger to pry up and disconnect the top two interconnect cable press connectors from the bottom edge of the motherboard.
  23. Google Pixel 9 Motherboard Replacement, Unscrew the motherboard: Schritt 23, Bild 1 von 1
    Standoff Screwdriver for iPhones
    $5.49
    • Remove the two screws securing the motherboard:
    • One 2.9 mm-long 3IP Torx Plus screw
    • One 5 mm-long standoff screw
  24. Google Pixel 9 Motherboard Replacement, Lift up the motherboard: Schritt 24, Bild 1 von 3 Google Pixel 9 Motherboard Replacement, Lift up the motherboard: Schritt 24, Bild 2 von 3 Google Pixel 9 Motherboard Replacement, Lift up the motherboard: Schritt 24, Bild 3 von 3
    • Insert the tip of a spudger underneath the bottom right corner of the motherboard.
    • Lift up with the spudger to dislodge the motherboard.
    • Lift the motherboard up until you can grip it with your fingers.
  25. Google Pixel 9 Motherboard Replacement, Remove the motherboard: Schritt 25, Bild 1 von 2 Google Pixel 9 Motherboard Replacement, Remove the motherboard: Schritt 25, Bild 2 von 2
    • Remove the motherboard.
  26. Google Pixel 9 Motherboard Replacement, Thermal pad reassembly information: Schritt 26, Bild 1 von 3 Google Pixel 9 Motherboard Replacement, Thermal pad reassembly information: Schritt 26, Bild 2 von 3 Google Pixel 9 Motherboard Replacement, Thermal pad reassembly information: Schritt 26, Bild 3 von 3
    • Check the condition of the logic board thermal pad—it will either be on the bottom of the logic board or on the frame.
    • If the pad is undamaged, skip the rest of this step.
    • If the pad is damaged, use the flat end of a spudger to scrape it up and remove it.
    • Use isopropyl alcohol (greater than 90%) and a microfiber cloth to remove all thermal pad residue from the frame and bottom of the logic board.
    • Apply a new thermal pad to its spot on the frame.
  27. Google Pixel 9 Motherboard Replacement, Disconnect the flash: Schritt 27, Bild 1 von 2 Google Pixel 9 Motherboard Replacement, Disconnect the flash: Schritt 27, Bild 2 von 2
    • Use the tip of a spudger to pry up and disconnect the flash connector from the motherboard.
  28. Google Pixel 9 Motherboard Replacement, Disconnect the wide camera: Schritt 28, Bild 1 von 2 Google Pixel 9 Motherboard Replacement, Disconnect the wide camera: Schritt 28, Bild 2 von 2
    • Use the tip of a spudger to pry up and disconnect the wide camera.
  29. Google Pixel 9 Motherboard Replacement, Disconnect the ultrawide camera: Schritt 29, Bild 1 von 2 Google Pixel 9 Motherboard Replacement, Disconnect the ultrawide camera: Schritt 29, Bild 2 von 2
    • Use the tip of a spudger to pry up and disconnect the ultrawide camera.
  30. Google Pixel 9 Motherboard Replacement, Remove the motherboard: Schritt 30, Bild 1 von 2 Google Pixel 9 Motherboard Replacement, Remove the motherboard: Schritt 30, Bild 2 von 2
    • Remove the rear camera module from the motherboard.
  31. Google Pixel 9 Motherboard Replacement: Schritt 31, Bild 1 von 1
    • Only the motherboard remains.
Abschluss
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Pixel 9 Answers Community for help.
Eine weitere Person hat diese Anleitung absolviert.
Carsten Frauenheim
157.769 Reputation
439 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
123 Mitglieder
23.992 Anleitungen geschrieben
1 Kommentar zur Anleitung
Hello there, maybe someone know where buy motherboard for pixel 9 pro?
Никита Костецкий - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 11
Letzte 7 Tage: 63
Letzte 30 Tage: 250
Insgesamt: 3,409
