Zum Hauptinhalt wechseln
Google Pixel 9 Pro XL Front Facing Camera Replacement
Was du brauchst
  1. Google Pixel 9 Pro XL Front Facing Camera Replacement, Safety precautions: Schritt 1, Bild 1 von 2 Google Pixel 9 Pro XL Front Facing Camera Replacement, Safety precautions: Schritt 1, Bild 2 von 2
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables and completely power down your phone.
  2. Google Pixel 9 Pro XL Front Facing Camera Replacement, Adhesive information: Schritt 2, Bild 1 von 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Adhesive information: Schritt 2, Bild 2 von 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Adhesive information: Schritt 2, Bild 3 von 3
    • Adhesive secures the perimeter of the rear cover to the frame.
    • When separating the adhesive, don't insert your tool more than 3 mm under the rear cover to avoid damaging the internal components.
    • Measure 3 mm from the tip and mark your opening pick with a permanent marker. Alternatively, you can tape a coin to a pick 3 mm from the tip.
  3. Google Pixel 9 Pro XL Front Facing Camera Replacement, Apply a suction handle: Schritt 3, Bild 1 von 2 Google Pixel 9 Pro XL Front Facing Camera Replacement, Apply a suction handle: Schritt 3, Bild 2 von 2
    • Attach a suction handle to the bottom edge of the rear cover, as close to the edge as possible.
  4. Google Pixel 9 Pro XL Front Facing Camera Replacement, Insert an opening pick: Schritt 4, Bild 1 von 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Insert an opening pick: Schritt 4, Bild 2 von 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Insert an opening pick: Schritt 4, Bild 3 von 3
    • Pull up on the suction handle with strong, steady force to create a small gap under the rear cover.
    • Insert the tip of an opening pick in the gap.
  5. Google Pixel 9 Pro XL Front Facing Camera Replacement, Separate the rear cover adhesive: Schritt 5, Bild 1 von 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Separate the rear cover adhesive: Schritt 5, Bild 2 von 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Separate the rear cover adhesive: Schritt 5, Bild 3 von 3
    • Slide your opening along the bottom edge to separate the adhesive securing it.
    • Remember: don't insert the opening pick deeper than 3 mm.
  6. Google Pixel 9 Pro XL Front Facing Camera Replacement: Schritt 6, Bild 1 von 3 Google Pixel 9 Pro XL Front Facing Camera Replacement: Schritt 6, Bild 2 von 3 Google Pixel 9 Pro XL Front Facing Camera Replacement: Schritt 6, Bild 3 von 3
    • Slide your opening pick up the left edge and along the top edge to separate the adhesive.
  7. Google Pixel 9 Pro XL Front Facing Camera Replacement: Schritt 7, Bild 1 von 3 Google Pixel 9 Pro XL Front Facing Camera Replacement: Schritt 7, Bild 2 von 3 Google Pixel 9 Pro XL Front Facing Camera Replacement: Schritt 7, Bild 3 von 3
    • Slide your pick down the right edge to separate the remaining adhesive.
  8. Google Pixel 9 Pro XL Front Facing Camera Replacement, Prop up the rear cover: Schritt 8, Bild 1 von 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Prop up the rear cover: Schritt 8, Bild 2 von 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Prop up the rear cover: Schritt 8, Bild 3 von 3
    • Don't try to fully remove the rear cover yet, as a ribbon cable on the right edge connects it to the phone.
    • Use the suction handle to lift the left edge of the rear cover and swing it over the right edge, like opening the cover of a book.
    • If you're having trouble, check the perimeter for any remaining adhesive and use your opening pick to separate it.
    • Prop up the rear cover with the suction handle so you can access the ribbon cable near the top right corner.
  9. Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the cable cover: Schritt 9, Bild 1 von 2 Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the cable cover: Schritt 9, Bild 2 von 2
    • Use a Torx Plus 3IP screwdriver to remove the two 5.2 mm‑long screws securing the cable cover.
  10. Google Pixel 9 Pro XL Front Facing Camera Replacement: Schritt 10, Bild 1 von 2 Google Pixel 9 Pro XL Front Facing Camera Replacement: Schritt 10, Bild 2 von 2
    • Use tweezers or your fingers to remove the cable cover.
  11. Google Pixel 9 Pro XL Front Facing Camera Replacement, Disconnect the rear cover: Schritt 11, Bild 1 von 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Disconnect the rear cover: Schritt 11, Bild 2 von 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Disconnect the rear cover: Schritt 11, Bild 3 von 3
    • Use the point of a spudger to pry up and disconnect the rear cover press connector.
  12. Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the rear cover: Schritt 12, Bild 1 von 1
    • Remove the rear cover.
    • During reassembly, follow this guide to apply new adhesive and install your back cover.
  13. Google Pixel 9 Pro XL Front Facing Camera Replacement, Peel up the cable cover tape: Schritt 13, Bild 1 von 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Peel up the cable cover tape: Schritt 13, Bild 2 von 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Peel up the cable cover tape: Schritt 13, Bild 3 von 3
    • Use the tip of a spudger and your fingers to peel up the piece of tape near the left edge of your phone, enough that you can access the bracket and screws underneath.
    • You can completely remove the tape if you want, but be sure to keep it for reassembly.
  14. Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the cable cover: Schritt 14, Bild 1 von 2 Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the cable cover: Schritt 14, Bild 2 von 2
    • Use a Torx Plus 3IP screwdriver to remove the two 5.2 mm‑long screws securing the wireless charging cable cover.
  15. Google Pixel 9 Pro XL Front Facing Camera Replacement: Schritt 15, Bild 1 von 2 Google Pixel 9 Pro XL Front Facing Camera Replacement: Schritt 15, Bild 2 von 2
    • Use tweezers or your fingers to remove the cover.
  16. Google Pixel 9 Pro XL Front Facing Camera Replacement, Disconnect the wireless charging assembly: Schritt 16, Bild 1 von 2 Google Pixel 9 Pro XL Front Facing Camera Replacement, Disconnect the wireless charging assembly: Schritt 16, Bild 2 von 2
    • Use the tip of an opening pick to pry up and disconnect the wireless charging press‑connector.
  17. Google Pixel 9 Pro XL Front Facing Camera Replacement: Schritt 17, Bild 1 von 3 Google Pixel 9 Pro XL Front Facing Camera Replacement: Schritt 17, Bild 2 von 3 Google Pixel 9 Pro XL Front Facing Camera Replacement: Schritt 17, Bild 3 von 3
    • Use the point of a spudger to pry up and disconnect the ultra‑wideband press connector.
  18. Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the wireless charging assembly screws: Schritt 18, Bild 1 von 2 Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the wireless charging assembly screws: Schritt 18, Bild 2 von 2
    • Use a Torx Plus 3IP screwdriver to remove the two 2.2 mm‑long screw securing the wireless charging assembly.
  19. Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the wireless charging assembly: Schritt 19, Bild 1 von 2 Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the wireless charging assembly: Schritt 19, Bild 2 von 2
    • Remove the wireless charging assembly.
  20. Google Pixel 9 Pro XL Front Facing Camera Replacement, Disconnect the battery: Schritt 20, Bild 1 von 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Disconnect the battery: Schritt 20, Bild 2 von 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Disconnect the battery: Schritt 20, Bild 3 von 3
    • Use a spudger to pry up and disconnect the battery press connector.
  21. Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the 5G mmWave cover screw: Schritt 21, Bild 1 von 2 Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the 5G mmWave cover screw: Schritt 21, Bild 2 von 2
    • Use a Torx Plus 3IP screwdriver to remove the 5.2 mm‑long screw securing the mmWave antenna cover.
  22. Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the 5G mmWave cover: Schritt 22, Bild 1 von 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the 5G mmWave cover: Schritt 22, Bild 2 von 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the 5G mmWave cover: Schritt 22, Bild 3 von 3
    • A tight metal clip secures the bottom left corner of the mmWave antenna cover.
    • Insert the point of a spudger under the tab near the bottom left corner of the mmWave antenna cover.
    • Use your spudger to slide the cover to the right while prying up to unclip the cover.
  23. Google Pixel 9 Pro XL Front Facing Camera Replacement: Schritt 23, Bild 1 von 3 Google Pixel 9 Pro XL Front Facing Camera Replacement: Schritt 23, Bild 2 von 3 Google Pixel 9 Pro XL Front Facing Camera Replacement: Schritt 23, Bild 3 von 3
    • Gently pull the right edge of the cover towards the bottom of the phone and remove the cover.
    • During reassembly, insert the two tabs on the top corners under their recesses in the frame and push the cover down to clip it into place.
  24. Google Pixel 9 Pro XL Front Facing Camera Replacement, Disconnect the 5G mmWave antenna: Schritt 24, Bild 1 von 2 Google Pixel 9 Pro XL Front Facing Camera Replacement, Disconnect the 5G mmWave antenna: Schritt 24, Bild 2 von 2
    • Use the point of a spudger to pry up and disconnect the mmWave antenna press connector from the top right corner of the logic board.
  25. Google Pixel 9 Pro XL Front Facing Camera Replacement, Disconnect the front facing camera: Schritt 25, Bild 1 von 2 Google Pixel 9 Pro XL Front Facing Camera Replacement, Disconnect the front facing camera: Schritt 25, Bild 2 von 2
    • Use the point of a spudger to pry up and disconnect the front facing camera press connector.
  26. Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the 5G mmWave screw: Schritt 26, Bild 1 von 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the 5G mmWave screw: Schritt 26, Bild 2 von 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the 5G mmWave screw: Schritt 26, Bild 3 von 3
    • Be very careful not to touch the cameras during this step. If you accidentally do, wipe them with a clean microfiber or lint‑free cloth.
    • Carefully hold the front facing camera cable out of the way so you can access the mmWave antenna screw.
    • Use a Torx Plus 3IP screwdriver to remove the 4.2 mm‑long screw securing the mmWave antenna.
  27. Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the 5G mmWave antenna: Schritt 27, Bild 1 von 2 Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the 5G mmWave antenna: Schritt 27, Bild 2 von 2
    • Use tweezers or your fingers to remove the mmWave antenna.
    • During reassembly, make sure the mmWave antenna goes under the front facing camera cable.
  28. Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the front facing camera: Schritt 28, Bild 1 von 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the front facing camera: Schritt 28, Bild 2 von 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the front facing camera: Schritt 28, Bild 3 von 3
    • Light adhesive secures the front facing camera in place.
    • Use the point of a spudger to lift the right edge of the front facing camera, separating its adhesive.
    • Use tweezers or your fingers to remove the camera.
  29. Google Pixel 9 Pro XL Front Facing Camera Replacement, Apply new front camera adhesive: Schritt 29, Bild 1 von 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Apply new front camera adhesive: Schritt 29, Bild 2 von 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Apply new front camera adhesive: Schritt 29, Bild 3 von 3
    • Use tweezers to remove the old front facing camera adhesive from the frame.
    • Remove the larger clear liner from the front facing camera adhesive.
    • Use tweezers to carefully place the adhesive into the front facing camera recess.
    • Use a spudger to press the adhesive into place, securing it to the frame.
    • Remove the remaining blue liner from the adhesive.
  30. Google Pixel 9 Pro XL Front Facing Camera Replacement, Install your replacement front camera: Schritt 30, Bild 1 von 2 Google Pixel 9 Pro XL Front Facing Camera Replacement, Install your replacement front camera: Schritt 30, Bild 2 von 2
    • Remove any protective caps or liners from your replacement front facing camera.
    • With the cable on the right edge, press the front facing camera into its recess to secure it with the adhesive.
Abschluss
To reassemble your device, follow these instructions in reverse order starting with this step.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Eine weitere Person hat diese Anleitung absolviert.
Spencer Day
119.619 Reputation
838 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
119 Mitglieder
21.990 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 46
Insgesamt: 489
