Zum Hauptinhalt wechseln
Google Pixel 9 Rear Camera Module Replacement
Was du brauchst
  1. Google Pixel 9 Rear Camera Module Replacement, Prepare your Pixel for disassembly: Schritt 1, Bild 1 von 3 Google Pixel 9 Rear Camera Module Replacement, Prepare your Pixel for disassembly: Schritt 1, Bild 2 von 3 Google Pixel 9 Rear Camera Module Replacement, Prepare your Pixel for disassembly: Schritt 1, Bild 3 von 3
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Completely power off your phone.
    • Press the power and volume up buttons at the same time to bring up the shutdown menu.
  2. Google Pixel 9 Rear Camera Module Replacement, Adhesive information: Schritt 2, Bild 1 von 3 Google Pixel 9 Rear Camera Module Replacement, Adhesive information: Schritt 2, Bild 2 von 3 Google Pixel 9 Rear Camera Module Replacement, Adhesive information: Schritt 2, Bild 3 von 3
    • Adhesive secures the perimeter of the back glass to the frame.
    • When separating the adhesive, don't insert your tool more than 3 mm under the back glass to avoid damaging the internal components.
    • To help, measure and mark 3 mm from the tip of an opening pick with a permanent marker.
    • If your screen or back glass is badly cracked, a suction cup may not perfectly adhere.
    • Lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier. Ensure there's a smooth area near the bottom edge that's large and smooth enough for a suction cup to stick to.
  3. Google Pixel 9 Rear Camera Module Replacement, Apply a suction handle: Schritt 3, Bild 1 von 2 Google Pixel 9 Rear Camera Module Replacement, Apply a suction handle: Schritt 3, Bild 2 von 2
    • Place a suction handle at the bottom edge of the back glass, as close to the edge as possible.
    • Push down to attach the suction cup.
  4. Google Pixel 9 Rear Camera Module Replacement, Insert an opening pick: Schritt 4, Bild 1 von 3 Google Pixel 9 Rear Camera Module Replacement, Insert an opening pick: Schritt 4, Bild 2 von 3 Google Pixel 9 Rear Camera Module Replacement, Insert an opening pick: Schritt 4, Bild 3 von 3
    • Pull up on the suction handle with strong, steady force to create a small gap under the back glass.
    • Insert the tip of an opening pick into the gap.
  5. Google Pixel 9 Rear Camera Module Replacement, Separate the back glass adhesive: Schritt 5, Bild 1 von 3 Google Pixel 9 Rear Camera Module Replacement, Separate the back glass adhesive: Schritt 5, Bild 2 von 3 Google Pixel 9 Rear Camera Module Replacement, Separate the back glass adhesive: Schritt 5, Bild 3 von 3
    • Slide the opening pick back and forth along the bottom edge to separate the adhesive securing it.
    • Remember: don't insert the opening pick deeper than 3 mm.
  6. Google Pixel 9 Rear Camera Module Replacement: Schritt 6, Bild 1 von 3 Google Pixel 9 Rear Camera Module Replacement: Schritt 6, Bild 2 von 3 Google Pixel 9 Rear Camera Module Replacement: Schritt 6, Bild 3 von 3
    • Slide the opening pick around the perimeter of the phone, slicing the rest of the adhesive.
  7. Google Pixel 9 Rear Camera Module Replacement: Schritt 7, Bild 1 von 3 Google Pixel 9 Rear Camera Module Replacement: Schritt 7, Bild 2 von 3 Google Pixel 9 Rear Camera Module Replacement: Schritt 7, Bild 3 von 3
    • With most of the adhesive separated, lightly twist the opening pick at the bottom edge to lift the back glass up until you can grip it with your fingers.
    • Use the opening pick to separate any remaining sections of adhesive securing the back glass.
  8. Google Pixel 9 Rear Camera Module Replacement, Remove the back glass: Schritt 8, Bild 1 von 1
    • Remove the back glass.
    • During reassembly:
    • Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
    • Follow this guide to apply new adhesive and install your back glass.
  9. Google Pixel 9 Rear Camera Module Replacement, Remove the upper board cover: Schritt 9, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    FixMat
    $31.41
    • While the Pixel 9 uses Torx Plus screws, standard Torx bits also work. Make sure to apply constant, downward force to prevent stripping.
    • Use a 3IP Torx Plus driver to remove the single 5.4 mm‑long screw securing the upper board cover.
  10. Google Pixel 9 Rear Camera Module Replacement: Schritt 10, Bild 1 von 2 Google Pixel 9 Rear Camera Module Replacement: Schritt 10, Bild 2 von 2
    • Use a pair of tweezers to remove the upper board cover.
  11. Google Pixel 9 Rear Camera Module Replacement, Remove the midframe: Schritt 11, Bild 1 von 1
    • Use a 3IP Torx driver to remove the five screws securing the midframe and wireless charging coil:
    • Four 5.4 mm-long screws
    • One 2.2 mm-long screw
  12. Google Pixel 9 Rear Camera Module Replacement, Peel up the flash cable: Schritt 12, Bild 1 von 2 Google Pixel 9 Rear Camera Module Replacement, Peel up the flash cable: Schritt 12, Bild 2 von 2
    • Use a pair of tweezers to peel the flash cable off of the metal midframe.
  13. Google Pixel 9 Rear Camera Module Replacement, Remove the midframe: Schritt 13, Bild 1 von 2 Google Pixel 9 Rear Camera Module Replacement, Remove the midframe: Schritt 13, Bild 2 von 2
    • Remove the midframe, wireless charging coil, and NFC assembly.
  14. Google Pixel 9 Rear Camera Module Replacement, Disconnect the battery: Schritt 14, Bild 1 von 2 Google Pixel 9 Rear Camera Module Replacement, Disconnect the battery: Schritt 14, Bild 2 von 2
    • Use the tip of a spudger to pry up and disconnect the battery connector.
  15. Google Pixel 9 Rear Camera Module Replacement, Disconnect the 5G mmWave antenna: Schritt 15, Bild 1 von 3 Google Pixel 9 Rear Camera Module Replacement, Disconnect the 5G mmWave antenna: Schritt 15, Bild 2 von 3 Google Pixel 9 Rear Camera Module Replacement, Disconnect the 5G mmWave antenna: Schritt 15, Bild 3 von 3
    • Use the tip of a spudger to pry up and disconnect the 5G mmWave antenna's press connector.
  16. Google Pixel 9 Rear Camera Module Replacement, Remove the 5G mmWave antenna: Schritt 16, Bild 1 von 3 Google Pixel 9 Rear Camera Module Replacement, Remove the 5G mmWave antenna: Schritt 16, Bild 2 von 3 Google Pixel 9 Rear Camera Module Replacement, Remove the 5G mmWave antenna: Schritt 16, Bild 3 von 3
    • Remove the 5G mmWave antenna.
    • A small flex cable attaches to the back of the antenna with a press connector. You may need to reconnect it if it falls off.
    • During reassembly, insert the antenna so it's between the frame and the small metal bracket near the top right corner.
  17. Google Pixel 9 Rear Camera Module Replacement, Remove the antenna board cover: Schritt 17, Bild 1 von 1
    • Use a 3IP Torx Plus driver to remove the 5.4 mm-long screw securing the antenna board cover.
  18. Google Pixel 9 Rear Camera Module Replacement: Schritt 18, Bild 1 von 1
    • Use a pair of tweezers to remove the antenna board cover.
  19. Google Pixel 9 Rear Camera Module Replacement, Disconnect the autofocus cable: Schritt 19, Bild 1 von 2 Google Pixel 9 Rear Camera Module Replacement, Disconnect the autofocus cable: Schritt 19, Bild 2 von 2
    • Use the tip of a spudger to pry up and disconnect the autofocus connector from the motherboard.
  20. Google Pixel 9 Rear Camera Module Replacement, Disconnect the antenna cable: Schritt 20, Bild 1 von 2 Google Pixel 9 Rear Camera Module Replacement, Disconnect the antenna cable: Schritt 20, Bild 2 von 2
    • Insert one arm of a pair of angled tweezers under the metal neck of the antenna board's coaxial antenna cable.
    • Lift straight up to disconnect the antenna.
  21. Google Pixel 9 Rear Camera Module Replacement, Disconnect the front camera: Schritt 21, Bild 1 von 2 Google Pixel 9 Rear Camera Module Replacement, Disconnect the front camera: Schritt 21, Bild 2 von 2
    • Use the tip of a spudger to pry up and disconnect the front camera press connector.
  22. Google Pixel 9 Rear Camera Module Replacement, Disconnect the interconnect cables: Schritt 22, Bild 1 von 3 Google Pixel 9 Rear Camera Module Replacement, Disconnect the interconnect cables: Schritt 22, Bild 2 von 3 Google Pixel 9 Rear Camera Module Replacement, Disconnect the interconnect cables: Schritt 22, Bild 3 von 3
    • Use the tip of a spudger to pry up and disconnect the top two interconnect cable press connectors from the bottom edge of the motherboard.
  23. Google Pixel 9 Rear Camera Module Replacement, Unscrew the motherboard: Schritt 23, Bild 1 von 1
    Standoff Screwdriver for iPhones
    $5.49
    • Remove the two screws securing the motherboard:
    • One 2.9 mm-long 3IP Torx Plus screw
    • One 5 mm-long standoff screw
  24. Google Pixel 9 Rear Camera Module Replacement, Lift up the motherboard: Schritt 24, Bild 1 von 3 Google Pixel 9 Rear Camera Module Replacement, Lift up the motherboard: Schritt 24, Bild 2 von 3 Google Pixel 9 Rear Camera Module Replacement, Lift up the motherboard: Schritt 24, Bild 3 von 3
    • Insert the tip of a spudger underneath the bottom right corner of the motherboard.
    • Lift up with the spudger to dislodge the motherboard.
    • Lift the motherboard up until you can grip it with your fingers.
  25. Google Pixel 9 Rear Camera Module Replacement, Remove the motherboard: Schritt 25, Bild 1 von 2 Google Pixel 9 Rear Camera Module Replacement, Remove the motherboard: Schritt 25, Bild 2 von 2
    • Remove the motherboard.
  26. Google Pixel 9 Rear Camera Module Replacement, Thermal pad reassembly information: Schritt 26, Bild 1 von 3 Google Pixel 9 Rear Camera Module Replacement, Thermal pad reassembly information: Schritt 26, Bild 2 von 3 Google Pixel 9 Rear Camera Module Replacement, Thermal pad reassembly information: Schritt 26, Bild 3 von 3
    • Check the condition of the logic board thermal pad—it will either be on the bottom of the logic board or on the frame.
    • If the pad is undamaged, skip the rest of this step.
    • If the pad is damaged, use the flat end of a spudger to scrape it up and remove it.
    • Use isopropyl alcohol (greater than 90%) and a microfiber cloth to remove all thermal pad residue from the frame and bottom of the logic board.
    • Apply a new thermal pad to its spot on the frame.
  27. Google Pixel 9 Rear Camera Module Replacement, Disconnect the flash: Schritt 27, Bild 1 von 2 Google Pixel 9 Rear Camera Module Replacement, Disconnect the flash: Schritt 27, Bild 2 von 2
    • Use the tip of a spudger to pry up and disconnect the flash connector from the motherboard.
  28. Google Pixel 9 Rear Camera Module Replacement, Disconnect the wide camera: Schritt 28, Bild 1 von 2 Google Pixel 9 Rear Camera Module Replacement, Disconnect the wide camera: Schritt 28, Bild 2 von 2
    • Use the tip of a spudger to pry up and disconnect the wide camera.
  29. Google Pixel 9 Rear Camera Module Replacement, Disconnect the ultrawide camera: Schritt 29, Bild 1 von 2 Google Pixel 9 Rear Camera Module Replacement, Disconnect the ultrawide camera: Schritt 29, Bild 2 von 2
    • Use the tip of a spudger to pry up and disconnect the ultrawide camera.
  30. Google Pixel 9 Rear Camera Module Replacement, Remove the motherboard: Schritt 30, Bild 1 von 2 Google Pixel 9 Rear Camera Module Replacement, Remove the motherboard: Schritt 30, Bild 2 von 2
    • Remove the rear camera module from the motherboard.
  31. Google Pixel 9 Rear Camera Module Replacement: Schritt 31, Bild 1 von 1
    • Only the motherboard remains.
  32. Google Pixel 9 Rear Camera Module Replacement, Remove the rear camera module: Schritt 32, Bild 1 von 3 Google Pixel 9 Rear Camera Module Replacement, Remove the rear camera module: Schritt 32, Bild 2 von 3 Google Pixel 9 Rear Camera Module Replacement, Remove the rear camera module: Schritt 32, Bild 3 von 3
    • Check if there's an autofocus sensor pre‑installed on the top of your replacement rear cameras. If there isn't, follow the remaining steps to remove and transfer the sensor from your old cameras.
    • Use a pair of tweezers to gently peel the autofocus and flash assembly off of the rear camera module, being very careful not to damage the cable or press connectors.
    • If you're having trouble, use an iOpener or hair dryer to lightly heat the sensor.
    • Only the rear camera module remains.
  33. Google Pixel 9 Rear Camera Module Replacement, Install new flash module adhesive: Schritt 33, Bild 1 von 3 Google Pixel 9 Rear Camera Module Replacement, Install new flash module adhesive: Schritt 33, Bild 2 von 3 Google Pixel 9 Rear Camera Module Replacement, Install new flash module adhesive: Schritt 33, Bild 3 von 3
    • Use a spudger and tweezers to remove the two pieces of adhesive from the bottom of the LDAF and flash module.
    • Remove the larger clear liners from one of the flash module adhesives.
    • Place the adhesive into place on the bottom of the module and press down firmly with the flat end of a spudger to secure the adhesive.
    • Repeat the process to apply the other piece of flash adhesive.
    • Remove the two remaining blue liners.
  34. Google Pixel 9 Rear Camera Module Replacement, Transfer the autofocus sensor: Schritt 34, Bild 1 von 2 Google Pixel 9 Rear Camera Module Replacement, Transfer the autofocus sensor: Schritt 34, Bild 2 von 2
    • Be very careful not to touch the camera lenses during this step. If you accidentally do, wipe them with a clean microfiber or lint‑free cloth.
    • If your replacement rear cameras have protective caps or liners, remove them.
    • Carefully lay the sensor over the rear camera and press it into place, securing it with the adhesive.
    • The side with the longer cable should be over the smaller camera.
Abschluss
To reassemble your device, follow these instructions in reverse order starting with this step.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Pixel 9 Answers Community for help.
Carsten Frauenheim
146.267 Reputation
424 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
119 Mitglieder
21.959 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 10
Letzte 7 Tage: 49
Letzte 30 Tage: 162
Insgesamt: 1,130
