Zum Hauptinhalt wechseln
Google Pixel Slate Front-Facing Camera Replacement
Was du brauchst
  1. Google Pixel Slate Front-Facing Camera Replacement, Screen: Schritt 1, Bild 1 von 3 Google Pixel Slate Front-Facing Camera Replacement, Screen: Schritt 1, Bild 2 von 3 Google Pixel Slate Front-Facing Camera Replacement, Screen: Schritt 1, Bild 3 von 3
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body.
    • Use the suction cup to remove the screen from the body of the device.
  2. Google Pixel Slate Front-Facing Camera Replacement: Schritt 2, Bild 1 von 3 Google Pixel Slate Front-Facing Camera Replacement: Schritt 2, Bild 2 von 3 Google Pixel Slate Front-Facing Camera Replacement: Schritt 2, Bild 3 von 3
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
  3. Google Pixel Slate Front-Facing Camera Replacement, Front-Facing Camera: Schritt 3, Bild 1 von 3 Google Pixel Slate Front-Facing Camera Replacement, Front-Facing Camera: Schritt 3, Bild 2 von 3 Google Pixel Slate Front-Facing Camera Replacement, Front-Facing Camera: Schritt 3, Bild 3 von 3
    • Once removed, place the screen face down.
    • Peel back the black, adhesive strip covering the front camera so that the silver plate is exposed.
  4. Google Pixel Slate Front-Facing Camera Replacement: Schritt 4, Bild 1 von 3 Google Pixel Slate Front-Facing Camera Replacement: Schritt 4, Bild 2 von 3 Google Pixel Slate Front-Facing Camera Replacement: Schritt 4, Bild 3 von 3
    • Hold back the adhesive tape to expose the two black 2mm screws that are holding down the cover plate.
    • Use the T2 Torx screwdriver to remove the two 2mm screws.
  5. Google Pixel Slate Front-Facing Camera Replacement: Schritt 5, Bild 1 von 2 Google Pixel Slate Front-Facing Camera Replacement: Schritt 5, Bild 2 von 2
    • Once the two 2mm screws are removed, lift and remove the cover plate.
  6. Google Pixel Slate Front-Facing Camera Replacement: Schritt 6, Bild 1 von 2 Google Pixel Slate Front-Facing Camera Replacement: Schritt 6, Bild 2 von 2
    • Pull upwards on the flat wire to remove the front-facing camera from the device.
    • The camera may be secured to the screen body with adhesive tape. Apply gentle force to remove the camera by removing the tape.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Spencer Alonge
648 Reputation
5 Anleitungen geschrieben
Cal Poly, Team S2-G5, Maness Spring 2019 Mitglied von Cal Poly, Team S2-G5, Maness Spring 2019
CPSU-MANESS-S19S2G5
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 798
