Zum Hauptinhalt wechseln
Google Pixel Slate Screen Replacement
Was du brauchst
  1. Google Pixel Slate Screen Replacement, Screen: Schritt 1, Bild 1 von 3 Google Pixel Slate Screen Replacement, Screen: Schritt 1, Bild 2 von 3 Google Pixel Slate Screen Replacement, Screen: Schritt 1, Bild 3 von 3
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body.
    • Use the suction cup to remove the screen from the body of the device.
  2. Google Pixel Slate Screen Replacement: Schritt 2, Bild 1 von 3 Google Pixel Slate Screen Replacement: Schritt 2, Bild 2 von 3 Google Pixel Slate Screen Replacement: Schritt 2, Bild 3 von 3
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Spencer Alonge
648 Reputation
5 Anleitungen geschrieben
Cal Poly, Team S2-G5, Maness Spring 2019 Mitglied von Cal Poly, Team S2-G5, Maness Spring 2019
CPSU-MANESS-S19S2G5
4 Mitglieder
11 Kommentare
Where did you source the replacement screen? Can we get a link added to the parts list?
Brandon Price - Antwort
Anyone know where to source the replacement screen? Any help would be greatly appreciated.
Yeah, I could use the replacement source as well. Thanks.
Benjamin Reese - Antwort
me too! the resource replacement link plz!!
gabriela urquidi - Antwort
Is the screen held down with adhesive or does it have any clips? Also, does anyone know where I could source any Pixel Slate parts?
Kevin Freyre - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 21
Letzte 30 Tage: 59
Insgesamt: 4,537
