Zum Hauptinhalt wechseln
Google Pixel Slate Speaker Replacement
Was du brauchst
  1. Google Pixel Slate Speaker Replacement, Screen: Schritt 1, Bild 1 von 3 Google Pixel Slate Speaker Replacement, Screen: Schritt 1, Bild 2 von 3 Google Pixel Slate Speaker Replacement, Screen: Schritt 1, Bild 3 von 3
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body.
    • Use the suction cup to remove the screen from the body of the device.
  2. Google Pixel Slate Speaker Replacement: Schritt 2, Bild 1 von 3 Google Pixel Slate Speaker Replacement: Schritt 2, Bild 2 von 3 Google Pixel Slate Speaker Replacement: Schritt 2, Bild 3 von 3
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
  3. Google Pixel Slate Speaker Replacement, Speaker: Schritt 3, Bild 1 von 3 Google Pixel Slate Speaker Replacement, Speaker: Schritt 3, Bild 2 von 3 Google Pixel Slate Speaker Replacement, Speaker: Schritt 3, Bild 3 von 3
    • There are two speakers, one on each side of the Google Pixel Slate. This guide works for either one.
    • Use the T2 Torx screwdriver to remove the yellow 2mm screw from the thin metal plate.
    • Use the T3 Torx screwdriver to remove the pink 3mm screw from the thin metal plate.
    • Remove the thin metal plate from the device.
  4. Google Pixel Slate Speaker Replacement: Schritt 4, Bild 1 von 1
    • Use the T2 Torx screwdriver to remove the two black 2mm screws from the speaker.
  5. Google Pixel Slate Speaker Replacement: Schritt 5, Bild 1 von 2 Google Pixel Slate Speaker Replacement: Schritt 5, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use the Nylon-Tipped Tweezers to remove the black plug.
    • There is a red and a black wire connected to the black plug.
    • Pull the black plug in an upwards direction.
    • Be sure to gently remove plug, as using too much force can damage the connecting wires.
  6. Google Pixel Slate Speaker Replacement: Schritt 6, Bild 1 von 2 Google Pixel Slate Speaker Replacement: Schritt 6, Bild 2 von 2
    • Use the Nylon-Tipped Tweezers to disconnect the black tape-like plug connected to the speaker.
  7. Google Pixel Slate Speaker Replacement: Schritt 7, Bild 1 von 2 Google Pixel Slate Speaker Replacement: Schritt 7, Bild 2 von 2
    • Detach the speaker wire from the motherboard.
    • Remove the adhesive strips that hold down the speaker wire.
  8. Google Pixel Slate Speaker Replacement: Schritt 8, Bild 1 von 3 Google Pixel Slate Speaker Replacement: Schritt 8, Bild 2 von 3 Google Pixel Slate Speaker Replacement: Schritt 8, Bild 3 von 3
    • Use the T2 Torx screwdriver to remove the 2mm black screw from the brass plate.
    • Pull back the brass plate.
  9. Google Pixel Slate Speaker Replacement: Schritt 9, Bild 1 von 1
    • You can now remove the speaker from the device.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Spencer Alonge
648 Reputation
5 Anleitungen geschrieben
Cal Poly, Team S2-G5, Maness Spring 2019 Mitglied von Cal Poly, Team S2-G5, Maness Spring 2019
CPSU-MANESS-S19S2G5
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 15
Insgesamt: 882
