Zum Hauptinhalt wechseln
Google Pixelbook Display Replacement
Was du brauchst
  1. Google Pixelbook Display Replacement, Battery (Back Panel): Schritt 1, Bild 1 von 3 Google Pixelbook Display Replacement, Battery (Back Panel): Schritt 1, Bild 2 von 3 Google Pixelbook Display Replacement, Battery (Back Panel): Schritt 1, Bild 3 von 3
    • Use the iFixit opening tools or a metal spudger to pry the rubber covers off the back of your Pixelbook.
    • Peel the linings off completely until the back of the Pixelbook looks bare.
  2. Google Pixelbook Display Replacement: Schritt 2, Bild 1 von 2 Google Pixelbook Display Replacement: Schritt 2, Bild 2 von 2
    • Remove the two yellow 2.0mm screws by using a T3 Torx screwdriver.
  3. Google Pixelbook Display Replacement: Schritt 3, Bild 1 von 3 Google Pixelbook Display Replacement: Schritt 3, Bild 2 von 3 Google Pixelbook Display Replacement: Schritt 3, Bild 3 von 3
    • Remove the seventeen 3.0mm T5 Torx screws from the bottom panel.
  4. Google Pixelbook Display Replacement: Schritt 4, Bild 1 von 3 Google Pixelbook Display Replacement: Schritt 4, Bild 2 von 3 Google Pixelbook Display Replacement: Schritt 4, Bild 3 von 3
    • Use the nylon spudger to pry the edge of the Pixelbook up until you can grab the edge with your fingers.
    • Open the back panel completely and lay it flat so you see the whole inside of the computer.
  5. Google Pixelbook Display Replacement: Schritt 5, Bild 1 von 2 Google Pixelbook Display Replacement: Schritt 5, Bild 2 von 2
    • Remove the yellow 2.0mm screw from the middle of the panel by using the T3 Torx screwdriver to turn the screw counterclockwise.
  6. Google Pixelbook Display Replacement: Schritt 6, Bild 1 von 2 Google Pixelbook Display Replacement: Schritt 6, Bild 2 von 2
    • Remove the small, black casing by using the spudger to lift it up from its place.
  7. Google Pixelbook Display Replacement: Schritt 7, Bild 1 von 1
    • Disconnect the flat, black cord from the main component by using a spudger to push it out of the slot, or by using your hand to carefully pull it out.
    • Your back panel is now free from the main component.
  8. Google Pixelbook Display Replacement, Display Board: Schritt 8, Bild 1 von 1
    • Use an iSclack, or suction cup, to lift up the corner of the display from the case.
  9. Google Pixelbook Display Replacement: Schritt 9, Bild 1 von 3 Google Pixelbook Display Replacement: Schritt 9, Bild 2 von 3 Google Pixelbook Display Replacement: Schritt 9, Bild 3 von 3
    • Insert an opening pick into the gap between the display and case.
    • Repeat this procedure on other side.
  10. Google Pixelbook Display Replacement: Schritt 10, Bild 1 von 1
    • Using an opening pick, slowly pry up on the display until it separates.
    • Don't completely remove the display as ribbon cables connect it to the case.
  11. Google Pixelbook Display Replacement: Schritt 11, Bild 1 von 3 Google Pixelbook Display Replacement: Schritt 11, Bild 2 von 3 Google Pixelbook Display Replacement: Schritt 11, Bild 3 von 3
    • Use the pointed end of spudger to flip up the small locking flap on the ZIF connector.
    • Remove the display ribbon cable from the socket.
  12. Google Pixelbook Display Replacement: Schritt 12, Bild 1 von 3 Google Pixelbook Display Replacement: Schritt 12, Bild 2 von 3 Google Pixelbook Display Replacement: Schritt 12, Bild 3 von 3
    • Use the pointed end of a spudger to flip up the small locking flap on the ZIF connector.
  13. Google Pixelbook Display Replacement: Schritt 13, Bild 1 von 3 Google Pixelbook Display Replacement: Schritt 13, Bild 2 von 3 Google Pixelbook Display Replacement: Schritt 13, Bild 3 von 3
    • Flip the display over and lay it flat on the keyboard.
  14. Google Pixelbook Display Replacement: Schritt 14, Bild 1 von 3 Google Pixelbook Display Replacement: Schritt 14, Bild 2 von 3 Google Pixelbook Display Replacement: Schritt 14, Bild 3 von 3
    • Use a pair of tweezers to grab the clip on the display connector and swing it over to the other side of the socket.
    • Pull on the clip to disconnect the display.
    • Remove the display.
Abschluss
11 weitere Nutzer:innen haben diese Anleitung absolviert.
Blake Klein
70.531 Reputation
50 Anleitungen geschrieben
9 Kommentare
Where would you find a replacement display?
Carlos Garcia - Antwort
Any idea on where to get a display replacement for the Pixelbook?
Nicolas - Antwort
Is it necessary to remove the back in order to remove the screen? I cant see any connection between the two?
Thanks
Stevie B - Antwort
You remove the back to disconnect the battery.
Sergio B -
any idea how to remove the glass shade on the back panel?
jon - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 14
Letzte 30 Tage: 95
Insgesamt: 10,409
