Einleitung
In this guide, you will learn how to replace the right charging port on your Google Pixelbook Go to fix charging issues.
Was du brauchst
Flip the device so that the back is facing up.
Peel the rubber stoppers off the top and bottom of the device.
Remove ten 3 mm screws from around the edge of the back panel using a T5 Torx screwdriver.
Use an iFixit opening tool to pry up the back panel cover.
Remove the single 2 mm screw using a Torx T3 screwdriver.
Disconnect the orange cable from the base of the device.
Remove the three pink screws from the right charging port using a T3 Torx screwdriver.
Remove the right charging port by picking it up and lifting it from the computer.
