Einleitung
In this guide, you will learn how to replace the left charging port on your Google Pixelbook to fix charging issues.
  1. Use the iFixit opening tools or a metal spudger to pry the rubber covers off the back of your Pixelbook.
    • Use the iFixit opening tools or a metal spudger to pry the rubber covers off the back of your Pixelbook.
    • Peel the linings off completely until the back of the Pixelbook looks bare.
  2. Remove the two yellow 2.0mm screws by using a T3 Torx screwdriver.
    • Remove the two yellow 2.0mm screws by using a T3 Torx screwdriver.
    • Remove the seventeen 3.0mm T5 Torx screws from the bottom panel.
    • Use the nylon spudger to pry the edge of the Pixelbook up until you can grab the edge with your fingers.
    • Open the back panel completely and lay it flat so you see the whole inside of the computer.
    • Remove the yellow 2.0mm screw from the middle of the panel by using the T3 Torx screwdriver to turn the screw counterclockwise.
    • Remove the small, black casing by using the spudger to lift it up from its place.
    • Disconnect the flat, black cord from the main component by using a spudger to push it out of the slot, or by using your hand to carefully pull it out.
    • Your back panel is now free from the main component.
    • Remove the two 3.0mm silver screws from the thin, black component by using a T3 Torx screwdriver to turn the screws counterclockwise.
    • Disconnect the thin, black and white cord from the motherboard by using the spudger to snap the connector up and out of place.
    • Remove the thin, black component by pulling it up and out of the laptop with your fingers.
    • This photo shows the bottom screw still in the black box, but yours should be removed.
    • Remove the gold 2.0mm corner screw by turning it counterclockwise with a T3 Torx screwdriver.
    • Using needle-nose tweezers, remove the silver casing by lifting it up and out of the computer.
    • Remove the three 3.0mm black screws on the right side by using a T5 Torx screwdriver to turn the screws counterclockwise.
    • Remove the silver 2.0mm screw on the left side by using a T3 Torx screwdriver to turn the screw counterclockwise.
    • Disconnect the thin, black ribbon cable by using the spudger to lift it up from the computer.
    • Use the needle-nose tweezers to remove the charging port by lifting the component up and out of the Pixelbook.
Abschluss
Alon Gary
Mitglied seit 24.01.2018
319 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S18-G1, Livingston Winter 2018 Mitglied von Cal Poly, Team S18-G1, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G1
4 Mitglieder
6 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 39
Insgesamt: 485
