Zum Hauptinhalt wechseln
Google Pixelbook Right Charging Port Replacement
Was du brauchst
  1. Google Pixelbook Right Charging Port Replacement, Battery (Back Panel): Schritt 1, Bild 1 von 3 Google Pixelbook Right Charging Port Replacement, Battery (Back Panel): Schritt 1, Bild 2 von 3 Google Pixelbook Right Charging Port Replacement, Battery (Back Panel): Schritt 1, Bild 3 von 3
    • Use the iFixit opening tools or a metal spudger to pry the rubber covers off the back of your Pixelbook.
    • Peel the linings off completely until the back of the Pixelbook looks bare.
  2. Google Pixelbook Right Charging Port Replacement: Schritt 2, Bild 1 von 2 Google Pixelbook Right Charging Port Replacement: Schritt 2, Bild 2 von 2
    • Remove the two yellow 2.0mm screws by using a T3 Torx screwdriver.
  3. Google Pixelbook Right Charging Port Replacement: Schritt 3, Bild 1 von 3 Google Pixelbook Right Charging Port Replacement: Schritt 3, Bild 2 von 3 Google Pixelbook Right Charging Port Replacement: Schritt 3, Bild 3 von 3
    • Remove the seventeen 3.0mm T5 Torx screws from the bottom panel.
  4. Google Pixelbook Right Charging Port Replacement: Schritt 4, Bild 1 von 3 Google Pixelbook Right Charging Port Replacement: Schritt 4, Bild 2 von 3 Google Pixelbook Right Charging Port Replacement: Schritt 4, Bild 3 von 3
    • Use the nylon spudger to pry the edge of the Pixelbook up until you can grab the edge with your fingers.
    • Open the back panel completely and lay it flat so you see the whole inside of the computer.
  5. Google Pixelbook Right Charging Port Replacement: Schritt 5, Bild 1 von 2 Google Pixelbook Right Charging Port Replacement: Schritt 5, Bild 2 von 2
    • Remove the yellow 2.0mm screw from the middle of the panel by using the T3 Torx screwdriver to turn the screw counterclockwise.
  6. Google Pixelbook Right Charging Port Replacement: Schritt 6, Bild 1 von 2 Google Pixelbook Right Charging Port Replacement: Schritt 6, Bild 2 von 2
    • Remove the small, black casing by using the spudger to lift it up from its place.
  7. Google Pixelbook Right Charging Port Replacement: Schritt 7, Bild 1 von 1
    • Disconnect the flat, black cord from the main component by using a spudger to push it out of the slot, or by using your hand to carefully pull it out.
    • Your back panel is now free from the main component.
  8. Google Pixelbook Right Charging Port Replacement, Right Charging Port: Schritt 8, Bild 1 von 2 Google Pixelbook Right Charging Port Replacement, Right Charging Port: Schritt 8, Bild 2 von 2
    • Remove the three 2.0mm black screws from the sound card by using a T5 Torx screwdriver to turn them counterclockwise.
    • Remove the gold 3.0mm screw by using a T3 Torx screwdriver to turn it counterclockwise.
  9. Google Pixelbook Right Charging Port Replacement: Schritt 9, Bild 1 von 1
    • Disconect the thin, black and red cord from the motherboard by using the spudger to snap the connector up and out of place.
  10. Google Pixelbook Right Charging Port Replacement: Schritt 10, Bild 1 von 1
    • Remove the yellow 2.0mm screw by using the T3 Torx screwdriver to turn the screw counterclockwise.
  11. Google Pixelbook Right Charging Port Replacement: Schritt 11, Bild 1 von 1
    • Remove the small, red component by lifting it up with the spudger.
  12. Google Pixelbook Right Charging Port Replacement: Schritt 12, Bild 1 von 1
    • Disconnect the metal component of the thin, black component by lifting it up with the spudger.
  13. Google Pixelbook Right Charging Port Replacement: Schritt 13, Bild 1 von 2 Google Pixelbook Right Charging Port Replacement: Schritt 13, Bild 2 von 2
    • Remove the right charging port by picking it up with the tweezers and lifting it from the computer.
Abschluss
Alon Gary
544 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S18-G1, Livingston Winter 2018 Mitglied von Cal Poly, Team S18-G1, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G1
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 1,581
