Einleitung
If your Gourmia GAF536 air fryer is plugged in and not turning on, a faulty power cord could be the cause. This guide will provide a nice and easy way to replace your power cord. There are no complicated tools required for this project.
Was du brauchst
Unscrew two 14mm x 6mm screws on bottom of air fryer with Ph 02 screwdriver.
Use a pair of scissors, cut off zip ties around wire.
Be sure to use electrical scissors, cut red and blue wires.
The faulty power chord can then be removed.
2 weitere Personen haben diese Anleitung absolviert.
