Einleitung
If the Gourmia GAF536 Air-Fryer is not level, wobbles when being used, or is scratching the surface it sits on, these bumpers are the likely cause and will need to be changed. In this replacement guide, the steps required to replace the rubber bumpers will be provided.
Was du brauchst
Use the halberd spudger to remove each bumper.
Eine weitere Person hat diese Anleitung absolviert.
