Zum Hauptinhalt wechseln
Governor Adjustment
Was du brauchst
  1. Governor Adjustment, Governor Adjustment: Schritt 1, Bild 1 von 3 Governor Adjustment, Governor Adjustment: Schritt 1, Bild 2 von 3 Governor Adjustment, Governor Adjustment: Schritt 1, Bild 3 von 3
    • Before starting, make sure the engine isn't running and is not hot.
    • Using needle-nose pliers, carefully unhook the spring from the end opposite the air filter.
  2. Governor Adjustment: Schritt 2, Bild 1 von 1
    • Use the needle-nose pliers to either lengthen or shorten the hook at the end of the spring.
    • If your engine is stalling or refusing to start, try shortening the spring. This will enable more fuel to reach to engine at idle. If the engine is bogged down when running and you hear liquids splashing, try lengthening the spring.
  3. Governor Adjustment: Schritt 3, Bild 1 von 1
    • Carefully re-hook the spring on the arm it was disconnected from.
Abschluss
Aaron Correya
239 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S25-G15, Maness Spring 2018 Mitglied von Cal Poly, Team S25-G15, Maness Spring 2018
CPSU-MANESS-S18S25G15
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 16
Letzte 30 Tage: 101
Insgesamt: 2,350
