Einleitung
This guide shows how to locate the screws on the handle cover and remove them to allow the handle cover to come off. This is only necessary if there is a problem in collapsing the stroller.
Was du brauchst
Flip the stroller over so that the screws on the handle are facing upwards.
Locate the four 22 mm Phillips screws on the underside of the handle.
Using a Phillips #1 screwdriver, remove the four 22 mm screws and set them aside.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
