Zum Hauptinhalt wechseln
Graco Paint Sprayers 17C325 2015 Gun Filter Replacement
Was du brauchst
  1. Graco Paint Sprayers 17C325 2015 Gun Filter Replacement, Remove the Handle: Schritt 1, Bild 1 von 3 Graco Paint Sprayers 17C325 2015 Gun Filter Replacement, Remove the Handle: Schritt 1, Bild 2 von 3 Graco Paint Sprayers 17C325 2015 Gun Filter Replacement, Remove the Handle: Schritt 1, Bild 3 von 3
    • Before you begin, make sure to follow the pressure relief procedure documented in the user manual before disconnecting and disassembling the spray gun.
    • Unscrew and remove the handle from the spray gun body.
    • You may need to use a pipe wrench to loosen the handle before removing it.
  2. Graco Paint Sprayers 17C325 2015 Gun Filter Replacement, Remove the Filter: Schritt 2, Bild 1 von 3 Graco Paint Sprayers 17C325 2015 Gun Filter Replacement, Remove the Filter: Schritt 2, Bild 2 von 3 Graco Paint Sprayers 17C325 2015 Gun Filter Replacement, Remove the Filter: Schritt 2, Bild 3 von 3
    • Use your fingers to remove the blue-tipped filter from the inside of the handle.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Craig Lloyd
35.673 Reputation
82 Anleitungen geschrieben
3 Kommentare
It would be beneficial to have the part numbers in this information as well! Otherwise, great job! Thanks
JANET - Antwort
part number for the gun filter??????
BRITTINEY - Antwort
288749 60 mesh gun filter
RICHARD -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 16
Letzte 30 Tage: 57
Insgesamt: 1,917
