Zum Hauptinhalt wechseln
Graco Secure Coverage Speaker Replacement on Parent Unit
Was du brauchst
  1. Graco Secure Coverage  Speaker Replacement on Parent Unit, Parent Unit Battery: Schritt 1, Bild 1 von 3 Graco Secure Coverage  Speaker Replacement on Parent Unit, Parent Unit Battery: Schritt 1, Bild 2 von 3 Graco Secure Coverage  Speaker Replacement on Parent Unit, Parent Unit Battery: Schritt 1, Bild 3 von 3
    • Using plastic opening tool, pry and remove the battery lid.
  2. Graco Secure Coverage  Speaker Replacement on Parent Unit: Schritt 2, Bild 1 von 1
    • Remove the battery by holding the device with one hand and pulling the battery out with other hand carefully.
    • Make sure that you disconnect the battery's wire before you remove the battery.
  3. Graco Secure Coverage  Speaker Replacement on Parent Unit, Parent Unit Speaker: Schritt 3, Bild 1 von 2 Graco Secure Coverage  Speaker Replacement on Parent Unit, Parent Unit Speaker: Schritt 3, Bild 2 von 2
    • There are two screws on the rare case of the device. For the one shown in red marker requires either an extended screwdriver or putting on a little pressure on a regular screwdriver.
    • Remove the two 9mm Phillips #1 screws from the rare case of the device.
    • If you cannot remove the screw with low pressure, do not use high pressure to remove it. It may cause a damage on the device case. Use an extended screwdriver instead.
  4. Graco Secure Coverage  Speaker Replacement on Parent Unit: Schritt 4, Bild 1 von 2 Graco Secure Coverage  Speaker Replacement on Parent Unit: Schritt 4, Bild 2 von 2
    • Using opening plastic tool, pry the two grey cases from both sides of the device.
    • Take your time and apply constant force to avoid breaking or damaging any other plastic parts.
    • While pry off the grey cases, hold the device with your other hand to remove the cases.
  5. Graco Secure Coverage  Speaker Replacement on Parent Unit: Schritt 5, Bild 1 von 1
    • Pry the edges of the device to separate the front case away from the rare case.
    • While prying the edges, hold the device with one hand to pull out each case a part.
    • Make sure you use a constant force, and the pushbuttons are pried off completely.
  6. Graco Secure Coverage  Speaker Replacement on Parent Unit: Schritt 6, Bild 1 von 2 Graco Secure Coverage  Speaker Replacement on Parent Unit: Schritt 6, Bild 2 von 2
    • Remove the 7mm Phillips #1 screw from the mother board.
    • Place the screw in a secure place.
    • Pull out the mother board away from the case carefully.
  7. Graco Secure Coverage  Speaker Replacement on Parent Unit: Schritt 7, Bild 1 von 2 Graco Secure Coverage  Speaker Replacement on Parent Unit: Schritt 7, Bild 2 von 2
    • Pick up the motherboard.
    • Solder off the speaker from the device's case.
    • Solder off the speaker from the mother board.
    • There are many pins attached to the mother board, make sure you solder off the proper pins that attached to the speaker wires.
    • Replace the speaker.
Abschluss
Ahmed Elshaer
201 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 6-5, Remmell Fall 2015 Mitglied von USF Tampa, Team 6-5, Remmell Fall 2015
USFT-REMMELL-F15S6G5
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 171
