Zum Hauptinhalt wechseln
Graco Secure Coverage LED Nursery Unit Replacement
Was du brauchst
  1. Graco Secure Coverage LED Nursery Unit Replacement, Nursery Unit Battery: Schritt 1, Bild 1 von 3 Graco Secure Coverage LED Nursery Unit Replacement, Nursery Unit Battery: Schritt 1, Bild 2 von 3 Graco Secure Coverage LED Nursery Unit Replacement, Nursery Unit Battery: Schritt 1, Bild 3 von 3
    • Remove the 9mm screw from the battery cover of the nursery unit using a Phillips #1 tip screwdriver.
  2. Graco Secure Coverage LED Nursery Unit Replacement: Schritt 2, Bild 1 von 2 Graco Secure Coverage LED Nursery Unit Replacement: Schritt 2, Bild 2 von 2
    • Using the plastic opening tool, pry and remove the battery cover carefully.
    • Remove the batteries using plastic opening tool.
    • Replace the batteries.
  3. Graco Secure Coverage LED Nursery Unit Replacement, LED Nursery Unit: Schritt 3, Bild 1 von 2 Graco Secure Coverage LED Nursery Unit Replacement, LED Nursery Unit: Schritt 3, Bild 2 von 2
    • Remove the two 9mm Phillips #1 screws from the rare case of the device.
    • Place the screws in a secure place.
  4. Graco Secure Coverage LED Nursery Unit Replacement: Schritt 4, Bild 1 von 1
    • Hold the bottom of the device with one hand and pull down to separate the front and rare cases.
    • While holding the device with one hand, use plastic opening tool to pry the edges of the front case away from the back case.
    • Apply constant force carefully to avoid breaking any other plastic parts from the device.
  5. Graco Secure Coverage LED Nursery Unit Replacement: Schritt 5, Bild 1 von 2 Graco Secure Coverage LED Nursery Unit Replacement: Schritt 5, Bild 2 von 2
    • Remove all three 7mm Phillips #1 screws from the mother board.
    • Place the screws in secure place.
  6. Graco Secure Coverage LED Nursery Unit Replacement: Schritt 6, Bild 1 von 3 Graco Secure Coverage LED Nursery Unit Replacement: Schritt 6, Bild 2 von 3 Graco Secure Coverage LED Nursery Unit Replacement: Schritt 6, Bild 3 von 3
    • Flip over the motherboard to look at the LED pins that are connected to it.
    • Solder off the LED pin from the motherboard.
    • There are many pins are connect to the motherboard, so make sure that you solder off the LED pin.
    • Replace the LED.
Abschluss
Bryson Wolff
237 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 6-5, Remmell Fall 2015 Mitglied von USF Tampa, Team 6-5, Remmell Fall 2015
USFT-REMMELL-F15S6G5
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 162
