Einleitung
Use this guide to replace the LED on your Graco Secure Coverage Digital Baby Monitor for parent unit.
The LED replacement includes the LED and battery replacement.
Was du brauchst
Using plastic opening tool, pry and remove the battery lid.
Remove the battery by holding the device with one hand and pulling the battery out with other hand carefully.
Remove the two 9mm Phillips #1 screws from the rare case of the device.
Using opening plastic tool, pry the two grey cases from both sides of the device.
While pry off the grey cases, hold the device with your other hand to remove the cases
Pry the edges of the device to separate the front and rare cases.
While prying the edges, hold the device with one hand to pull out each case a part.
Remove the 7mm Phillips #1 screw from the mother board.
Place the screw in a secure place.
