Einleitung
Use this guide to replace the battery on your Graco Secure Coverage Digital Baby Monitor for nursery unit.
The battery replacement includes the battery replacement.
Was du brauchst
Remove the 9mm screw from the battery cover of the nursery unit using a Phillips #1 tip screwdriver.
Using the plastic opening tool, pry and remove the battery cover carefully.
Remove the batteries using plastic opening tool.
Replace the batteries.
