Einleitung
If the fork arm in The Buttonholer is not moving properly while being operated, chance are you need to replace the spring holding the arm.
  1. Unscrew the screw located underneath fork arm using a Flathead screwdriver. Unscrew the screw located underneath fork arm using a Flathead screwdriver. Unscrew the screw located underneath fork arm using a Flathead screwdriver.
    • Unscrew the screw located underneath fork arm using a Flathead screwdriver.
  2. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  3. Raise the fork arm so that it is parallel with the upper hook. Turn the lower hook towards you from the bottom, and remove. Turn the lower hook towards you from the bottom, and remove.
    • Raise the fork arm so that it is parallel with the upper hook.
    • Turn the lower hook towards you from the bottom, and remove.
  4. Remove the old spring from the hook. Add the new spring to the hook.
    • Remove the old spring from the hook.
    • Add the new spring to the hook.
Abschluss
Michael Sykes
552 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 3-6, Brown Fall 2014 Mitglied von USF Tampa, Team 3-6, Brown Fall 2014
USFT-BROWN-F14S3G6
5 Mitglieder
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 78
