Einleitung
If your HAMILTON-C1 has displayed that the battery power is low or is emitting a buzzer sound for around 2 minutes, this is an indication that the battery must be replaced.
A battery in the HAMILTON-C1 acts as a backup for the main power source which is through an outlet in the wall. Battery power is used to protect the HAMILTON-C1 from low power or power failures. If you notice that the battery percentage is not fully charged, consider connecting the HAMILTON-C1 to the primary power source to recharge the battery. However if the battery cannot keep its charge, replace the battery. It is crucial to have a full battery to ensure the safety of the patient.
Make sure to disconnect the device from any power source before beginning.
Was du brauchst
Orient the Hamilton-C1 monitor so the front view is facing you.
Pry open the battery cover flap located at number 10 of the graphic.
Use your Flathead 4 mm Screwdriver to attach the battery cover with two captive screws.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
