Zum Hauptinhalt wechseln
HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement
Medizinische Ausrüstung
Weder iFixit noch diese Reparaturanleitung werden vom Hersteller medizinischer Geräte unterstützt oder sind mit diesem verbunden.
Was du brauchst
  1. HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement, Air Filter: Schritt 1, Bild 1 von 2 HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement, Air Filter: Schritt 1, Bild 2 von 2
    • Turn the Hamilton-C1 so that the rear view of the device is facing you.
    • Use your fingers to grasp the current air filter located at number 4 of the graphic and pull the filter out of the slot.
  2. HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement: Schritt 2, Bild 1 von 1
    • Insert a new air filter into the slot located at number 4.
  3. HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement, Fan Filter: Schritt 3, Bild 1 von 2 HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement, Fan Filter: Schritt 3, Bild 2 von 2
    • Orient the Hamilton-C1 to the right side so that the gas connections are visible.
    • Grab and remove the fan filter located at location number 5 in the graphic.
  4. HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement: Schritt 4, Bild 1 von 1
    • Place a new fan filter into the designated slot.
  5. HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement, HEPA Filter: Schritt 5, Bild 1 von 2 HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement, HEPA Filter: Schritt 5, Bild 2 von 2
    • Orient the Hamilton-C1 so the back is facing you.
    • Remove the back panel as labeled by number 6 of the graphic using a Phillips #1 screwdriver.
  6. HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement: Schritt 6, Bild 1 von 1
    • Remove the current HEPA filter by pulling the filter outward and down.
    • Insert the new HEPA filter into the slot.
Abschluss
Tina Vo
538 Reputation
4 Anleitungen geschrieben
Cal Poly, Team S7-G11, Paton Spring 2020 Mitglied von Cal Poly, Team S7-G11, Paton Spring 2020
CPSU-PATON-S20S7G11
2 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 6
Letzte 30 Tage: 10
Insgesamt: 339
