Zum Hauptinhalt wechseln
HKC P771A Camera Replacement
Was du brauchst
  1. HKC P771A Camera Replacement, Camera: Schritt 1, Bild 1 von 3 HKC P771A Camera Replacement, Camera: Schritt 1, Bild 2 von 3 HKC P771A Camera Replacement, Camera: Schritt 1, Bild 3 von 3
    • Remove back of tablet using the plastic opening tool
    • Slide the opening tool between the back of the tablet and the digitizer
    • Lift along the edges until the back of the tablet and the digitizer are separated
  2. HKC P771A Camera Replacement: Schritt 2, Bild 1 von 2 HKC P771A Camera Replacement: Schritt 2, Bild 2 von 2
    • Remove yellow tape around the edges of the battery
    • The battery is located on the right side of the tablet when the screen is facing downwards and the camera is on top
  3. HKC P771A Camera Replacement: Schritt 3, Bild 1 von 3 HKC P771A Camera Replacement: Schritt 3, Bild 2 von 3 HKC P771A Camera Replacement: Schritt 3, Bild 3 von 3
    • Pry battery away from the back of the tablet until the battery is completely separated from the adhesive
  4. HKC P771A Camera Replacement: Schritt 4, Bild 1 von 1
    • Remove yellow tape that is securing the camera wires
  5. HKC P771A Camera Replacement: Schritt 5, Bild 1 von 2 HKC P771A Camera Replacement: Schritt 5, Bild 2 von 2
    • Remove silver foil from the back of the camera using the blue opening tool
  6. HKC P771A Camera Replacement: Schritt 6, Bild 1 von 1
    • Lift the bronze, L-shaped ribbon
    • The camera is attached to the end of this ribbon so it will move with it
  7. HKC P771A Camera Replacement: Schritt 7, Bild 1 von 1
    • Flip up the black bar located on the motherboard
    • The black bar is to the left of the camera, where the ribbon is attached to the motherboard
  8. HKC P771A Camera Replacement: Schritt 8, Bild 1 von 1
    • Remove the bronze, L-shaped ribbon from inside the black bar
  9. HKC P771A Camera Replacement: Schritt 9, Bild 1 von 1
    • Your camera is now removed from the tablet
Abschluss
Sara Hill
101 Reputation
2 Anleitungen geschrieben
Ohio State, Team 2-3, Garvin Fall 2015 Mitglied von Ohio State, Team 2-3, Garvin Fall 2015
OSU-GARVIN-F15S2G3
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 158
