Zum Hauptinhalt wechseln
HKC P771A Digitizer Replacement
Was du brauchst
  1. HKC P771A Digitizer Replacement, Digitizer: Schritt 1, Bild 1 von 2 HKC P771A Digitizer Replacement, Digitizer: Schritt 1, Bild 2 von 2
    • Remove back of tablet using the plastic opening tool
    • Slide the opening tool between the back of the tablet and the digitizer
    • Lift along the edges until the back of the tablet and the digitizer are separated
  2. HKC P771A Digitizer Replacement: Schritt 2, Bild 1 von 2 HKC P771A Digitizer Replacement: Schritt 2, Bild 2 von 2
    • Remove 4 screws located on the red motherboard
    • The red motherboard will be loose, but does not need to come completely unattached
  3. HKC P771A Digitizer Replacement: Schritt 3, Bild 1 von 1
    • Remove 7 screws located around the edges of the tablet
    • 5 screws are visible around the edges of the device and 2 screws are located underneath the red motherboard
  4. HKC P771A Digitizer Replacement: Schritt 4, Bild 1 von 1
    • Lift digitizer from the screen
    • After removing all of the screws, the screen should easily separate from the digitizer
  5. HKC P771A Digitizer Replacement: Schritt 5, Bild 1 von 1
    • Now you can replace the old digitizer with a new one
Abschluss
Sara Hill
101 Reputation
2 Anleitungen geschrieben
Ohio State, Team 2-3, Garvin Fall 2015 Mitglied von Ohio State, Team 2-3, Garvin Fall 2015
OSU-GARVIN-F15S2G3
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 251
