Zum Hauptinhalt wechseln
HKC P774A Digitizer Replacement
Was du brauchst
  1. HKC P774A Digitizer Replacement, Digitizer: Schritt 1, Bild 1 von 3 HKC P774A Digitizer Replacement, Digitizer: Schritt 1, Bild 2 von 3 HKC P774A Digitizer Replacement, Digitizer: Schritt 1, Bild 3 von 3
    • Insert the flat end of the spudger into the side of the device
    • This will create a gap between the device and screen housing.
    • Insert the plastic opening tool into this gap and move it along this gap.
    • Make sure not to bent the digitizer during this step.
    • The screen housing and device will now be separated.
  2. HKC P774A Digitizer Replacement: Schritt 2, Bild 1 von 3 HKC P774A Digitizer Replacement: Schritt 2, Bild 2 von 3 HKC P774A Digitizer Replacement: Schritt 2, Bild 3 von 3
    • Once the digitizer has been been removed from the body, disconnect the digitizer band from the motherboard.
    • Two small black pins (circled in red) will need to be unlocked.
    • Unlock the pins by pulling them outward with the tweezers.
    • Make sure the pins are released entirely before attempting to remove the band.
    • Remove the band using the tweezers.
  3. HKC P774A Digitizer Replacement: Schritt 3, Bild 1 von 3 HKC P774A Digitizer Replacement: Schritt 3, Bild 2 von 3 HKC P774A Digitizer Replacement: Schritt 3, Bild 3 von 3
    • Once the digitizer has been disconnected from the motherboard, the LCD screen must be removed from the digitizer.
    • Push open the tabs (circled in red) using the flat end of the plastic spudger.
    • Be sure not to bend the digitizer while prying.
    • Continue to release all tabs while continuing to pry the LCD away from the digitizer.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Montana Tech, Team 10-1, Shirk Fall 2015 Mitglied von Montana Tech, Team 10-1, Shirk Fall 2015
MTUM-SHIRK-F15S10G1
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 155
