Zum Hauptinhalt wechseln
HKC P776A Battery Replacement
Was du brauchst
  1. HKC P776A Battery Replacement, Separating Digitizer and Case: Schritt 1, Bild 1 von 1
    • Insert the plastic opening tool between the digitizer and the case.
    • Place the spudger in the gap created by the plastic opening tool to assist in separation.
  2. HKC P776A Battery Replacement: Schritt 2, Bild 1 von 2 HKC P776A Battery Replacement: Schritt 2, Bild 2 von 2
    • Slide the spudger along the perimeter of the device to fully separate the two pieces.
  3. HKC P776A Battery Replacement, Battery: Schritt 3, Bild 1 von 1
    • Insert the plastic opening tool between the battery and case.
    • Apply leverage to break the glue that is attaching the battery to the case.
  4. HKC P776A Battery Replacement: Schritt 4, Bild 1 von 1
    • Continue breaking the glue along the perimeter of the battery until the battery can be removed.
    • Breaking all the glue between the battery and case may take a long time.
  5. HKC P776A Battery Replacement: Schritt 5, Bild 1 von 2 HKC P776A Battery Replacement: Schritt 5, Bild 2 von 2
    • Using the soldering iron, heat up the solder that is attaching the battery to the motheboard.
    • The heat from the soldering iron may cause personal injury or damage the internal components of the tablet.
  6. HKC P776A Battery Replacement: Schritt 6, Bild 1 von 1
    • Suck up the leftover solder using the desoldering pump.
    • Remove the battery from the motherboard.
Abschluss
Ryan Gornati
409 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 7-6, Remmell Winter 2015 Mitglied von USF Tampa, Team 7-6, Remmell Winter 2015
USFT-REMMELL-W15S7G6
3 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 633
