Was du brauchst
Insert the plastic opening tool between the digitizer and the case.
Place the spudger in the gap created by the plastic opening tool to assist in separation.
Slide the spudger along the perimeter of the device to fully separate the two pieces.
Use your fingers to pop the screen out from the digitizer.
Use the tip of the spudger to release the latches on the motherboard.
Fast fertig!
Abschluss
